99 f23 accord wont start
Old May 27, 2009 | 02:22 PM
KraKimus's Avatar
Icon6 99 f23 accord wont start
so i cannot for the life of me figure out why my car wont start. its trying to it just wont. everything is hooked up right. i took my valve cover off and took out my cam and rocker arms etc then put them back on cause i was gonna change the head gasket because it kept overheating but i decided not to so i put everything back together and now it wont start...it'll turn over but it will never catch and start.
Old May 28, 2009 | 03:45 AM
ControlNode's Avatar
Default Re: 99 f23 accord wont start
Oh, its hosed. I'll take the car on your hands. j/k.
I say double check the cam timing. Being off a few teeth could make it not start. Clayton is only 1.5-2 hours from me.
Also I have to ask, you say "full dual exhaust". So you have one tip out the back for cyl 1&4 and another tip for 2&3? That is the only way I'd consider it full dual, but I've never heard of anyone doing that with a 4 cyl. So that would mean 2 cats, 2 mufflers and all.
Old May 28, 2009 | 07:38 AM
KraKimus's Avatar
well if clayton is only that far away from you why dont you come take a look at it?
Old May 28, 2009 | 09:19 AM
I'm busy working on my cars, main relay, or ECU (hoping not), in my EW4 hatch finished dieing during lunch today so I have to fix that. And I'm getting the B20Z hatch ready for body and paint. I'll sell ya my 99 Accord, F23A1 engine is great, auto tranny ain't.
Old May 28, 2009 | 09:31 AM
accord99power's Avatar
the obvious hasnt been mentioned are you getting fuel and spark? thats a start, and check if the timing belt is moving/dragging etc.
Old May 28, 2009 | 09:32 AM
i wonder the same?????
hey wanna ship me your f23 engine for free
Old May 30, 2009 | 04:18 AM
KraKimus's Avatar
full dual exhaust means cat back exhaust from the V6 accord
Old May 30, 2009 | 06:02 PM
OK just say "V6 cat back" then, since the V6 ain't even true dual exhaust, just another dual muffler setup.
Get anything figured on getting the car running yet?
Old May 30, 2009 | 07:26 PM
KraKimus's Avatar
yeah i think my timing is off....i stuck a long stick in the spark plug hole and rotated the crankshaft until the stick wouldn't come up anymore and set the camshaft where both the little notches went from left to right and it said "up" so i tought i did it right but i guess not
Old May 30, 2009 | 11:54 PM
pickleboo's Avatar
hey, does your engine at least have a spark at your spark plug, if so your timing is off, if not then your ignition module is burnt out. why I think this because when you try to start it few times it could some time burn it out. it well crank when the timing is correct but it doesn't mean its going to start up. good luck
sfazngiants
Feb 22, 2009 04:11 PM
jsmoothy78
Jul 12, 2008 04:22 PM
dynastix9
Jul 21, 2006 04:42 PM
jdmcivic1999
Feb 11, 2005 01:28 PM
