CAN I TURBO MY B16 AND KEEP AC??
Old May 27, 2009 | 12:14 PM
jdmasfuk's Avatar
Default CAN I TURBO MY B16 AND KEEP AC??
Hi i have a 00 si coupe with a b16 im looking to buy a turbo kit is there any kit out there that that will work with my ac i really dont want to remove it.. thanks for the help
Old May 27, 2009 | 12:21 PM
shailoche's Avatar
Default Re: CAN I TURBO MY B16 AND KEEP AC??
There certainly is a way to run a turbo with A/C. The issue is usually the turbo manifold and the placement of the turbo once it is installed.
Find yourself the right manifold and you should be able to keep your A/C.
Old May 27, 2009 | 12:27 PM
redlinetuning's Avatar
Full Race has a number of AC compatible manifolds
Old May 27, 2009 | 12:44 PM
cleansi's Avatar
sure there is you can find all types of manifolds and down pipes that are ac compatible it would even be cheaper to find aset up that aloud you to keep ac then paying sum 1 to make or alter a pipe depending on what set up what size turbo ,down pipe ect look in the forced induction stickies
420_EM1
Dec 21, 2013 03:22 PM
imcunner
Jul 29, 2008 08:47 AM
lovey408
May 24, 2007 11:31 AM
PogiDC5
May 22, 2006 11:56 PM
sxecustoms
Oct 18, 2003 09:29 PM
