Suspension & Brakes Theory, alignment, spring rates....
bad negative camber on one wheel only? HELP
Old May 27, 2009 | 09:42 AM
nickohlassss's Avatar
Icon2 bad negative camber on one wheel only? HELP
so i recently traded my teg for a single cam 96 ex civic coupe. the kid told me the car was hit before and it does have a reconstructed title, but the car seems mint and doesnt appear to have any frame damage etc.
anyways, i ended up noticing terrible negative camber on the right rear wheel. the cars pretty low and the other wheels have some camber but its obviously much worst. i replaced the lower control arm and no change.
i searched and found someone had said there knuckle/spindle was bent and that caused this problem. can anyone confirm this? do you think this just was never repaired after the car was hit? also, will this get worst and worst and be dangerous to drive like this? any input about bent knuckle/spindle or other input on the subject is greatly appreciated.
Old May 27, 2009 | 10:01 AM
STOCK_SOHC_DX's Avatar
Default Re: bad negative camber on one wheel only? HELP
did you get alignment?
Old May 27, 2009 | 01:43 PM
TunerN00b's Avatar
Right rear wheel? Check the trailing arm and UCA for straightness. There isn't really a "knuckle" in the back, but either (or both) of those 2 parts being bent could cause camber changes. A bent LCA would probably reduce camber if anything, so it probably isn't that.
Old May 27, 2009 | 01:45 PM
Tyson's Avatar
get an alignment. check measurements. if its all good after, then youre all good. get a new set of tires too.
Old May 27, 2009 | 01:59 PM
bmoua's Avatar
Old May 27, 2009 | 06:07 PM
slimjimming6688's Avatar
look at the upper controle arm compare to the other side
Old May 28, 2009 | 07:51 AM
thanks everyone im gonna check out the upper control arm and see if everything looks good. i hope its not the rear trailing arm aha.
Old May 28, 2009 | 10:02 AM
kommon_sense's Avatar
take the wheel off and inspect. make sure upper and lower control arms are good.
dhonda
May 15, 2011 03:50 PM
nickohlassss
May 27, 2009 09:53 AM
StolenTeg
Jul 2, 2006 11:26 PM
klomast3r
Sep 6, 2005 08:40 AM
MassScene
Mar 30, 2005 09:02 PM
