FS: BLOX 72mm Thottle Body, AEBS Intake Manifold
Blox 72mm throttle body: Made out of billet aluminum. Works with any D, B, H series. It's 72mm on both the inlet and outlet (most TB's are tapered down at the outlet)
120 picked up
AEBS Intake Manifold:Works with any B series head, minus GSR. Only problem is that the threads where the studs (that hold the fuel rail down) are screwed in, are stripped. So you would need to redo them with a helicoil. Any machine shop can do that for you. Shouldnt cost more than 20 bucks.
75 picked up
I can work something out if you want to take both!
120 picked up
75 picked up
FreshEG6!*
Feb 10, 2009 09:50 PM
