GT42R, Full-race, Hondata s300+ tons more!!
So all these parts are basically new, I did make 2 passes on the car and that's it. Everything is mounted right now, but can be pulled asap for interested people. PM or email for pics of anything you need a better look at. Willing to ship if shipping is paid for or a label is sent. I will also combine shipping if multiple parts are purchased. Paypal is accepted if 3% is added. Checks are accepted, but no product will ship or be given untill check clears, and Cash is always good.
Here's the list folks:
GSR head fully Ported with new valve seals and guides. 1900
Ferrea 1mm oversized valves, intake and exhaust
Polished combustion chambers
Ported by Ryan formally of pro-machine.
GSR Cams 75 <b>SOLD</b>
AEBS headstuds 100
SRR adjustable cam gears. 150 <b>SOLD</b>
Ls RS machine o-ringed and sleeved block. 2500
Balanced and polished ls crank with GSR gurtel and aebs gurtel studs.
Carrillo rods WITH Carr bolts! -Balanced
Custom CP pistons with oversized wrist pins. –Balanced
Hot tanked.
Moroso oil pan. 100 <b>SOLD</b>
Garrett GT4294R ball bearing turbo with polished compressor housing, and coated exhaust housing. 1900
Full-race t4 divided top mount manifold with duel 44mm wastegate flanges 1200
2 tial 44 blue wastgates with dump tubes. BLUE 300 each <b>SOLD</b><b>SOLD</b>
Tial Blue blow off valve. BLUE 200 <b>SOLD</b>
Full 4” v-band downpipe, custom made by Cortney Green 200
4” aluminum exhaust with burns muffler. 300
3 inch polished charge pipe 150 <b>SOLD</b>
Precision 1000hp intercooler 550
Eddlebrock Victor x intake manifold port matched to the head. 250 <b>SOLD</b>
Eddlebrock Victor x intake manifold machined for 8 injectrors 250
Hondata intake manifold gasket. 50 <b>SOLD</b>
blox 76mm throttle body. 200
Aeromtive fuel filter -10 50 <b>SOLD</b>
Aeromotive Eliminator fuel pump, with black aeromotive fittings. 350 <b>SOLD</b>
Aermotive Fuel pressure regulator -8 130 <b>SOLD</b>
Eddlebrock -10 fuel rail 100
Precision 1600cc injectors 300
FJO injector driver 100
-8 black nylon braided fuel feed line AND 200
-6 black nylon return line
Full-race sump and EK/EM1 gas tank. 150 tank
Hondata S300 WITH all options and p28 ecu 550 <b>SOLD</b>
AEM boost control solenoid. 75 <b>SOLD</b>
DEFI gauges with control unit. Boost, Fuel, and EGT, needs new egt sensor. 600
MSD digital 6 ignition 300
MSD Distributor 450
MSD HVCII coil 150
Power shut off switch. 50
Tech edge PRO wideband. 450
B16 tranny, freshly rebuilt with Quaife LSD 1000 <b>SOLD</b>
Drive shaft shop stage 5.9 axles, 950 <b>SOLD</b>
Tilton Twin disk clutch with release bearing and master with stainless line. 1300
Fully adjustable OMNI coilovers. 950
Omni front camber kit 100
Moroso catch can with -12 lines to valve cover and drain back. 100 <b>SOLD</b>
Avid Solid mounts. For EM1/EK 350
Fluyidyne duel core radiator. 300 <b>SOLD</b>
FAL Fan. 150 <b>SOLD</b>
Custom engine harness, all the crap removed and re-loomed. NOT Ghetto! 100
Full 12 point cage, With civic si shell attached. done by Dean./shell 5000
Stroud 5 point harness. black. 110
Stroud window net black 100
Si leather seats with blue inserts. 100
Duel gauge bezel surround . 45
SSR comps 17” wheels!! come with falken azenis, tons of life left! Original not knock offs! 2000
VIS carbon fiber hood. looks good, has a heat crack, Cheap! 200 <b>SOLD</b>
VIS carbon fiber side skirts. 150
Lenso 13” drag wheels with 24.5 Micky Thompson slicks installed, 5-6 passes. 500
Brand new interstate Battey, huge cranking amps. 80
Fully leagl stainless Battery box. 100
valvecover with 2 -12 an bungs welded on 50 <b>SOLD</b>
3" silcone couplers. with tbolt clanps 50 <b>SOLD</b>
Precision ball bearing oil restrictor 50
-10 turbo oil drain kit 50
arp oil pan blots 40
arp12 point chrome manifold bolts. Check them out on lightiningmotorsports.com 50 <b>SOLD</b>
22t waterpump 30 <b>SOLD</b>
oil pump 30
timing belt. 30 <b>SOLD</b>
shift linkage 50 <b>SOLD</b>
Thanks everybody!
Jesten Thompson
801-916-4130
Utahbmx@yahoo.com
AEBS headstuds 100
Hot tanked.
MSD Distributor 450
MSD HVCII coil 150
oil pump 30
Thanks everybody!
Jesten Thompson
801-916-4130
Utahbmx@yahoo.com
Dose the Moroso catch can come with all the fittings and line. And the stuff for the drain back. If i get it a would only need the weld bugs to the vc right?
Maybe 50 miles, maybe that's pushing it. The only dirty parts are where I put my greasy hands on them.
Valve? But I kinda want to keep them all together for whoever buys the clutch.
do u still got the oil pan is it for a gsr
also intrested in the timing belt and water pump
what motor is this?
where u located
what motor is this?
where u located
I do, it will fit all B-series, but I do have it on a GSR. Still have the water pump and timing belt. PM or give me a call and I can get it all out to you asap!
Thanks
