Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Distributor issue what is the best
Old May 26, 2009 | 04:44 PM
realride's Avatar
Default Distributor issue what is the best
So honda discontinue to make the B16-B18 OBD1 distributor. what is the best available one out there, that does not create timing errors on ECU.
thcx
benny
Old May 26, 2009 | 04:52 PM
Tyson's Avatar
Default Re: Distributor issue what is the best
distributor king on ebay.
benny, i have a hood prop for you if you still need it.
Old May 26, 2009 | 04:55 PM
realride's Avatar
tried 2 of them gave timing errors with my AEM ecu.
I did not try the high performance one with external coil.
yes i still need it.
benny
Old May 26, 2009 | 08:13 PM
smokin rubber's Avatar
did you try a different ecu?
Old May 26, 2009 | 09:06 PM
B20Monster's Avatar
if not ecu.. possibly the wiring. and not to sound like a noob, what's a timing error?
Old May 26, 2009 | 09:15 PM
racebum's Avatar
jdm importers? i just sold a spare jdm b18c dizzy for $75, i'm sure one of the places has a spare floating around. what did you fry anyway? usually it's just the coil that goes
Old May 26, 2009 | 09:28 PM
JW racing's Avatar
Thats why I like K-series....Honda ditched the dizzy for a reason.
Old May 26, 2009 | 09:43 PM
topdog's Avatar
factory or distributer king dizzy with new honda ignitor and external msd ss coil has always work for me. Also what kinda timing error is it? TDC, CYP or CKP i would check the resistance on the dizzy to see if that is the problem first. If not then will be in wiring or ecu problem. Or switch to coil on plug since you are running a EMS. My 2 cent
Old May 27, 2009 | 07:06 AM
JuanTushag's Avatar
yes he needs the hood prop,,, i couldnt find my jack handle all sunday!!!
Old May 27, 2009 | 11:21 AM
B20Monster's Avatar
if those obd1 distributors are hard to find, you can always convert to OBD2 distributor. they are everywhere and more cars came with bseries vtec motors.
Old May 28, 2009 | 01:07 PM
mc-integra111's Avatar
That kinda sucks. If the OBDI is discontinued, that doesn't bode well for my ODB0 stuff.
You could try King Motorsports at http://www.kingmotorsports.com/. I believe they offer some aftermarket OBD0, OBDI, and OBDII distributors.
Old May 30, 2009 | 03:44 AM
Natural Aspirations's Avatar
Pretty sure new from honda Obd-II distributors are now unavailable as well.
Old May 31, 2009 | 05:38 PM
rmcdaniels's Avatar
If you're using and AEM ECU, then get the Hall Effect trigger kit from Tony Palo and a 4-channel ignition controller (Twin-Fire if you don't mind keeping a spare on hand, or M&W if you do). The Twin-Fire boxes catch fire from time to time, but they are cheap enough to keep a spare on hand and AEM keeps replacing mine for free. Since I switched to COP my ignition has been flawless. My brother has tried a bunch of distributors, factory Honda/Acura, MSD, Distributor King, etc, and they keep giving him problems at the track. If you look at the signal on an oscilliscope, then you can see how jumpy the signal from the distributor is, while the Hall Effect setup is a perfect square wave. It makes for a smoother idle and no misfires under stress.
It's not the cheapest way to go, but your engine will run smoother, no misfires ever, and rock-solid ignition performance.
Old May 31, 2009 | 10:20 PM
realride's Avatar
it's not legal in h2
Old Jun 2, 2009 | 08:43 PM
JOE BD-0's Avatar
You don't SEEM to have a problem getting new rules passed...Sorry for the pun, I couldn't resist.....JB
Old Jun 2, 2009 | 09:30 PM
Battle2.0Eg's Avatar
*falls on floor*
Old Jun 2, 2009 | 09:32 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
+1 for converting a obd2 to obd1.. or just convert your engine harness dizzy plug to obd2 that way u have one plug to fuss with!
Old Jun 3, 2009 | 05:27 PM
JOE BD-0's Avatar
Benny,
We were having an unstable tach problem with the aim data system. We solved it by adding their little circuit board that cleaned up the signal and spit out a nice square wave. Maybe that sort of setup will work for you. good luck...
Old Jun 4, 2009 | 10:29 AM
JOE BD-0's Avatar
info on the piece...
http://www.aim-sportline.com/downloa...er_101_eng.pdf
and a photo....
http://www.pegasusautoracing.com/pro...asp?RecID=5476
hope this helps. good luck
Old Jun 4, 2009 | 01:08 PM
joe those links dont work
Old Jun 4, 2009 | 04:18 PM
JOE BD-0's Avatar
It looks like they only work when you click on them from Tyson's recent Mychron info thread?
I looked at the links from there this morning, and will try again now.....
yes, they work when accessed from
https://honda-tech.com/forums/road-racing-autocross-time-attack-19/hooking-up-tach-signal-mychron3-gold-xg-2513257/
Old Jun 4, 2009 | 04:40 PM
Tyson's Avatar
joe, you have to copy and paste the whole link, the real link. not the truncated link that the forum creates.
Old Jun 4, 2009 | 06:13 PM
JOE BD-0's Avatar
Damn internet OWNS me....Except BANGBUS, yeah......
Old Jun 5, 2009 | 04:13 AM
Lo-Buck EF's Avatar
Benny, try an MSD unit. the drag guys that still use dizzys usually use an msd with external coil.
Old Jun 5, 2009 | 07:03 AM
realride's Avatar
I just got the King distributor high perf with external coil
will see.
benny
