Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
JHPUSA: BLOX Tuner Series Type B B-series VTEC Camshafts & Dual Valve Springs!!
Old May 26, 2009 | 03:16 PM
JHPUSA's Avatar
Default JHPUSA: BLOX Tuner Series Type B B-series VTEC Camshafts & Dual Valve Springs!!
JHPUSA is Back on Honda-Tech!!
BLOX Combo Package Tuner Series (Type-B) Camshafts and Dual Valve Springs!!!
Blox Tuner Series camshafts are designed using standard, OEM lobe designs while Competition Series camshafts are designed and cast with wider primary and secondary lobes. Although both types offer increased power and torque, Competition Series camshafts place less stress on the valvetrain and provide greater stability at extreme RPM's. Consequently, all camshafts are cast using the same materials and standards as OEM sources.
BLOX Racing recommends upgrading to its high compression valves, heavy duty valve springs, and Ti retainers on certain applications.
B-series DOHC VTEC engine compatibility list:
B16A, B17A, B16B (CTR), B18C1 (GSR), B18C5 (US ITR), B18C-R (JDM ITR)
Type B Specs:
Intake (lift / duration) 0.489" / 266
Exhaust (lift / duration) 0.472" / 266
***PM FOR PRICING***
BLOX Racing valve springs are wound using super clean, chrome silicone alloy. These valve springs are designed and engineered for both high performance street driving and all-out racing conditions.
Each set provides maximum lift while preventing valve float and helps counter the effects of spring surge. These are perfect for naturally- aspirated and forced-induction engines.
Easy installation, no machining is required. Highly recommended for aftermarket, performance camshafts. For maximum results, use with BLOX Racing Ti retainers and high compression valves
Old May 26, 2009 | 04:52 PM
JHPUSA's Avatar
Default Re: JHPUSA: BLOX Tuner Series Type B B-series VTEC Camshafts & Dual Valve Springs!!
UP!!
Old May 27, 2009 | 12:14 PM
EK2.0's Avatar
UP
Old May 27, 2009 | 02:19 PM
InnerCityNinja's Avatar
Can you PM me a price for the set?
Old May 28, 2009 | 11:05 AM
JHPUSA's Avatar
to the top!
Old May 29, 2009 | 10:58 AM
JHPUSA's Avatar
Morning Bump!
Old Jun 3, 2009 | 10:58 AM
JHPUSA's Avatar
Make those purchases!!! Great Prices!!!
Old Sep 30, 2009 | 02:23 PM
94civicgsr's Avatar
price plz
Old Dec 19, 2009 | 03:29 PM
Junatr's Avatar
I wonder if they are still doing business......I'm sick of waiting for replies
Old Dec 13, 2010 | 04:14 PM
golf-mk3's Avatar
can u please pm me a price on a set of blox valve springs and retainers shipped to 12866. for a b18c1
Old Dec 13, 2010 | 06:44 PM
Honda Gen's Avatar
They are Banned from Honda-tech
DerekHollister
Mar 28, 2016 02:32 AM
ty521825
Oct 31, 2011 04:33 PM
AllShowNoGo727
May 5, 2011 07:41 PM
