99 Integra GSR Head for sale
I bought a complete GSR motor for my current build to use as my donor motor. I had planned on sending this head out to Laskey to have Portflow do the work on it. However I have found a better deal locally. So this head needs to go. It came from a running motor that had spun a bearing. The head appears to be fine with no bent valves or anything of that nature. The headgasket was in good shape when I pulled the motor apart leading me to believe that the head has not been over heated, thus not warped.
Now heres the bad news:
I had intentions of running different cams in this head so I sold the stock cams and cam gears. The head did not come with a vtec solenoid and I do not have an extra one. Does not come with valve cover. Also one manifold side is missing most of its studs, but thats a quick fix and fairly inexpensive. Other then that its complete with LMA's and Cam Caps.
Asking $375 shipped less if you pick it up. Pm is key!!
J2turbo21
Mar 16, 2003 08:21 PM
J2turbo21
Mar 14, 2003 09:01 PM
