DIY How to install copper o-rings in a Block
Old May 26, 2009 | 02:14 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default DIY How to install copper o-rings in a Block
I dont think we have one so i decided to do it.
It's a very easy task but if everyone is as **** as i am it has to be perfect. The best way to learn is buy trial and error. I had more error with this than anything else i've done.
First time i put my block together i was good in a cylinders except number 2. i had coolant inside the combustion chamber without even starting the car up...lol
Gap in the oring was slightly to big, start over.
So we will start with what you need,
End cutting tool
mallet with a wooden end
18 gauge copper wire
this is what GE says in their instructions, Here is what i add my personal preference and you will see why
a file
Golden eagle was even impressed with what i did.
first you want to measure out a little more than what you need around the cylinder. i measured out about a 1ft per cylinder just to be safe.
you want to file your end when you make your first cut because it will make it difficult to see if you actually made the connection between the 2 copper o-rings.
not good-you can see the gap.
here's how you do it
lay the o-ring in and gently tap
once you get to the end you should the other end. this is important IMO because you will make the o-ring seal perfect. Once you get to the end file your way into place. dont cut but file it down that way when you are perfect it will slide in place just snug enough but not to tight
here is a good one, but not perfect.
Here is a perfect one with both ends filed tell me where you find the lines. looks like a complete circle with no gaps.
I hope this helps people that run into problems like what i did.I like to do things myself.
Old May 26, 2009 | 03:38 PM
ralph11sec's Avatar
Default Re: DIY How to install copper o-rings in a Block
wow great job.
how did you make the grove in the cylinder?
Old May 26, 2009 | 03:43 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
the grove has to be machined down to .030 the 18 gauge wire is .040 thick
Old May 26, 2009 | 04:09 PM
CerealKiller's Avatar
GE has one on their site
http://www.goldeneaglemfg.com/includ...INGINSTALL.pdf
both DIY are ****.
Old May 26, 2009 | 04:16 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i know they do but they don't have anything about using a file. and this makes 1 less link that OUR members have to click to.
This is for the OCD at heart, people that want to be perfect because they are worried that they cant see the small gap and didn't do it right.
this makes it pretty much flawless and less of a chance to make a mistake. with filling your way down till it falls smoothly and snugly in the grove the lines o-rings will seal perfectly with no gap at all. non measurable anyway.
i like my filling technique
Old May 26, 2009 | 04:27 PM
Old May 26, 2009 | 04:33 PM
formby's Avatar
what does this do?
Old May 26, 2009 | 04:43 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
the o-rings if your asking.
well it will make a better headgasket seal and allow higher boost
Old May 26, 2009 | 04:58 PM
SPOOLINmatt's Avatar
although i agree with your method and its smart, my rings always look like picture #1 when i go to put my head on and i have never EVER had a temp spike or blown head gasket or anything. The copper just crushes to much for that imperfection to truly matter. everyime i remove my head, there is zero gap from the crush. Nice write up though.
Old May 26, 2009 | 05:19 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
yeah i unerstand that and i figured i was good until i found coolant in the cylinder...lol without putting pressure in the system.
so i choose to be as **** as possible
Old May 26, 2009 | 06:01 PM
ghostofnyc's Avatar
looks aight son lol
Old Jul 12, 2013 | 11:14 PM
Steeve_Civic's Avatar
Nice !
Old Jul 13, 2013 | 12:50 AM
wantboost's Avatar
Who is Mr Robot?
Good jnfo but a 4 year old thread
Old Aug 24, 2013 | 06:20 AM
I tried yesterday on my block
and on these cylinder below I think there is a little gap, do you think I need to remove it?
It is very hard to remove it, how can I do without damage the sleeve please?
Old Aug 24, 2013 | 06:36 AM
sharp pick and a light hammer to remove is what i have always used. your rings look fine, especially after they crush.
Old Aug 24, 2013 | 08:50 AM
thank you, I'll test with a sharp pick.
Even this one? I don't need to remove it?
Old Aug 24, 2013 | 07:21 PM
wantboost's Avatar
Who is Mr Robot?
There should be no gap between ends. When the ring crushes it mushrooms the top and doesn't expand the ring so you'd still have a gap
Old Aug 25, 2013 | 12:35 AM
Sorry don t understand, you advise me to remove it and try again with on gap?
Old Aug 25, 2013 | 02:13 AM
wantboost's Avatar
Who is Mr Robot?
Yes
Lay the wire in the groove (don't trim it from the spool it's on yet) and once you complete the circle around the groove cut off just a little bit extra and handfile the remainder until it's snug with no gap and no overlap/sharp edges on both cut ends
(I emphasize hand filing here, any electrical tool will remove too much too fast and you'll have to start over)
Old Aug 27, 2013 | 02:54 AM
Than you for your advices.
I remove it and did it again.
Old Oct 28, 2013 | 09:10 AM
HondaMotive's Avatar
Great thread ahobbs! You're the man!!!!
So are you WantBoost!
Old Oct 28, 2013 | 09:54 AM
Freemananana's Avatar
I saw this come up recently and I guess that's why it's being bumped. It is good info though. OP did a great job from what I can see.
Old Oct 28, 2013 | 10:03 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
lol, old school, well not old school. But nearly 5 years ago lol
Old Oct 29, 2013 | 03:24 AM
wantboost's Avatar
Who is Mr Robot?
Looks like you did it perfectly, as I see no gaps or edges. Well done, now just do it three more times lol
HAHA I try, just glad I could point you in the right direction. If you see Steeve_Civic's last post and pic that is what the end result should look like
It's great info and ahobbs is a very knowledgeable member and always more than willing to share his knowledge and experiences for the benefit of others
I still think this needs to be stickied or put in the FAQs at the very least
Well, old school hot rod technology but if it works then hey, that is all that matters lol
Speaking of ahobbs, how's the car? Haven't seen you post up in a bit
Old Oct 29, 2013 | 11:56 PM
It works fine on my car. 32PSI of boost for the moment without problem
