WTB built/semi built block b series NA
I'm located in NJ. I'm looking for a b18 block built to semi built. I have a b16a2 now and I'm going to use that head and a new set of cams, I just need a bigger bottom end that can be used for high reving. I am building a all motor application, so I'm jsut seeing whats out there that I can get. Eitehr GSR or type R, or whatever you have, just throw it at me. Thanks.
PM me I'm in woodbridge nj. I have a couple sleeved blocks with big 86mm bore including cams to use with the setup. Also have simple LS block with CTR pistons.
