Car won't work
Old Aug 19, 2002 | 10:36 AM
slowvic's Avatar
Default Car won't work
I recently did a tune up on my 91 si hatch thats bone stock, including fuel filter, wires, plugs, rotor button and distributor cap. It idles fine but then the check engine light comes on, with the ECU flashing 4 times. I tried flooring it in neutral, it can't get passed 3k rpms, and accellerates real nasty. I really need some help with this, i have to have my car running tonight. Any help would be great
Old Aug 19, 2002 | 10:42 AM
CRXtraMoney's Avatar
Default Re: Car won't work (slowvic)
4 flashes on the ECu is a crank position sensor error. My guess is that during the tune up you knocked this senosr off. Check for loose wires and plugs that are not connected tight.
Old Aug 19, 2002 | 10:54 AM
slowvic's Avatar
Default Re: Car won't work (CRXtraMoney)
Thanks but i don't think thats it, i can't even get the clips apart, the connection there is probably ok
Old Aug 19, 2002 | 11:19 AM
The crank position sensor can throw eronious errors. Have you taken out the ECU fuse under the hood and left it out for a minute so the ECU will reset and then checked to see if the car runns better?
Old Aug 19, 2002 | 11:51 AM
slowvic's Avatar
yeah just tried that, didn't work. I noticed that the car idles bad until the check engine light comes on, the it idles better but still won't pass 3k
Frost7177
Feb 12, 2012 12:02 PM
90integ
Jun 7, 2011 10:15 AM
turbozcteg
Apr 10, 2007 03:51 PM
crxtreme27
Jul 1, 2003 04:30 PM
