WTB full d series turbo kit $1000
Old May 26, 2009 | 10:31 AM
brutekiller787's Avatar
Default WTB full d series turbo kit $1000
like the title says i am looking to buy a full turbo kit everything included for around $1000 i don't really care if it's new or used as long as it is in good condition and works. looking for good quality stuff, no ebay ****. here's what i am looking for.
-t3/t4 turbo 57 trim with a 63. A/R exhaust housing
-matching turbo manifold, cast or stainless, as long as it isn't cracked, 38mm wastegate flange
-38mm wastegate with 7psi spring
-2.5" downpipe and dumptube with flanges for specified turbo and wastegate
-intercooler and piping kit, don't care what size as long as it supports 300+ hp, is rolled on the ends, and comes with couplers and t bolt clamps
-Any blow off valve and flange, better if the flange is already welded on charge piping. as long as it sounds good
-Oil feed and drain lines, oil pan fittings, restrictor, and some sort of adapter
-all vacuum lines and fittings
-25psi boost/vacuum gauge and vacuum line
-precision 440cc injectors or other 440/450cc injectors, must be high impedence
-walbro 225lph fuel pump for 96-00 civic
-stage 2 clutch, <5000 miles, must hold 250 hp
-possibly a p06 ecu, chipped or unchipped doesn't matter
-obd2a-obd1 conversion harness
basically everything needed to safely make, and tune to, 200hp on a stock d16y7
bump if you look thanks
looking to spend $1000 total for everything except ecu, will add 150 for ecu and conversion harness
Old May 26, 2009 | 10:34 AM
Suzukifreek's Avatar
Default Re: WTB full d series turbo kit $1000
ebay? 1000 is not much to work with sprry:/
Old May 26, 2009 | 12:10 PM
i have looked on ebay and heard the horror stories. i would get a kit on ebay but i want a fuel pump, injectors, clutch, ecu, and all of that and that brings me to about 1600 and i figured if some people on here have all that used i could bring the price down a bit.
also willing to include an xbox 360, never needed repair in really great shape, with 1 wireless controller and 20gb hard drive plus rock band 2, includes 2 wireless les paul guitars, 1 strat with effects switch removed, 1 mic, and one drumset, all in good shape except the bass pedal is broken, and skate 2
will include all of the above if turbo kit is offered
Old May 26, 2009 | 01:19 PM
tegman23's Avatar
I have a greddy kit, I would sell for that....I dont think you would find anything like your looking for, at that price
Old May 26, 2009 | 05:54 PM
bump
slowcivic e g
Nov 6, 2012 02:46 PM
slowcivic e g
Nov 4, 2012 12:19 PM
slowcivic e g
Mid-Atlantic (Sales)
May 7, 2012 02:10 PM
Live*JDM
Dec 1, 2007 02:05 AM
