b20 cylinder wall finish (also knife edge crank)
right new b20 block is here. (for my b20vtec)
all looks good but this time i am sending the block to an engineering place and having them do the hone. now, what are hondas wall finish specs for a b20z1 engine? (angle/hatch type/grade of stone/hone etc)
also do the walls taper down at all or should they be dead on straight from top to bottom?
also for piston rings should i go for a 0.25mm oversize ring then file them to fit for a closer tolerance? they are going on ycp itr spec b20 pistons (cast like oem etc)
is it worth paying extra for a knife edged crank btw? they can do it but do i need to supply the flywheel as well for them to balance it on etc?
also in regards to the head i am currently using the golden eagle stepped dowels, is there anyway i can alter the dowels so i can just use a genuine oem honda gasket and not have to drill the dowel holes out further? eagle pre cut ones are hella expensiave to get here in the uk.
thanks!
thanks!
frozenb
Oct 10, 2007 08:28 PM
camlob
Apr 22, 2006 11:18 PM
