H&R OE vs. Eibach prokit
Old Aug 19, 2002 | 09:58 AM
civicboy95's Avatar
Default H&R OE vs. Eibach prokit
i was originally going to get the prokits(1.4/1.3"). but now mebe i should get the h&R OE(.75"). I want a dorp that will not give me problems with tire wear and negative camber. I know the prokit is a quailty spring, but what about the HR ones? i dont want a really low drop, just enough to be noticed. Can someone please post pis of the h&R and their reviews on the springs? which should i go with?
Old Aug 19, 2002 | 10:23 AM
civicboy95's Avatar
Default Re: H&R OE vs. Eibach prokit (civicboy95)
anyboyd please?
Old Aug 19, 2002 | 10:27 AM
98slvrcx's Avatar
i dont know but a drop of less then an 1" will not be noticible at all. On a 96 and up civic i heard that you can go as high as sportlines and not have problems . If you go higher then 2" then thats where camber kits are really needed. I ordered my sportlines from coximport.com for 207 shipped and i cant wait to put them on .
Old Aug 19, 2002 | 10:28 AM
95civiccoupe31's Avatar
by a camber kit cheap ***
Old Aug 19, 2002 | 12:19 PM
deepnite's Avatar
Default Re: H&R OE vs. Eibach prokit (95civiccoupe31)
the pro kit is about 15% stiffer than stock and the drop is noticabble..but u can go lower without having to worry about excessive camber..some negative camber is good for cornering performance..under 2" should be ok..either the prokit or sportlines should be ok ..sportlines a a bit stiffer
Old Aug 19, 2002 | 12:25 PM
ITRacer121's Avatar
Default Re: H&R OE vs. Eibach prokit (deepnite)
my friends have both kits on thier 2 si's and they ride about the same hieght but the H&R's are alot stiffer in the bumps and corners
Dub C
Feb 22, 2006 12:34 AM
silva95teg
Jul 24, 2005 12:04 PM
Imprezn
Mar 6, 2003 09:20 PM
uNF$@#!
May 5, 2002 12:48 PM
Import RP
Apr 29, 2002 11:09 PM
