...:: LOVEthatDC2's GSR Build Thread ((Slow Build))::...
Old May 26, 2009 | 01:14 AM
LOVEthatDC2's Avatar
Default ...:: LOVEthatDC2's GSR Build Thread ((Slow Build))::...
Never made a build thread, never had to I guess ... well anyway, I just picked up my 94 LS the other day and had a GSR engine laying around so I figured it was 'meant to be' haha ...
I just want to build myself a reliable daily driver, that's it, nothing crazy. Will be swapping the engine, getting the side moldings taken off, getting it re-painted and maybe throwing a Type-R front (not sure) ... future plans also would include re-doing the suspension since it's pretty old but that's down the road.
Anyway, here goes! ... We took the block apart and found that the #1 cylinder had some rust on the cylinder wall from sitting for a while so I took it to a machine shop and they told me I should overbore it 0.20 over so I did that and got the pistons to match.
Got it back from the machine shop and here's how it sits for now ...
First thing I did after getting it back was painting the block
Ordered the ACL bearings, those should be in sometime this week and HOPEFULLY we can start the re-assemble
Old May 26, 2009 | 09:28 AM
mouab18c1's Avatar
Default Re: ...:: LOVEthatDC2's GSR Build Thread ((Slow Build))::...
i guess ill be the first to post. goodluck with the build
Old May 26, 2009 | 09:50 AM
haha yup! thanks man ... just ordered my ARP head studs right now, those should be in this week
Old May 26, 2009 | 10:12 AM
dapek's Avatar
In for this
Just a tip, you may want to go with OEM bearings. Although ACL bearings are great, you will get a substantially longer life from OEM and not have to replace them nearly as soon.
Old May 26, 2009 | 10:17 AM
Originally Posted by dapek
In for this
I'll have to get a price quote on OEM thanks for the tip!
Old Jul 15, 2009 | 11:02 PM
started assembly on the block .. well actually FINISHED assembly on the block (will post pics soon). Put the head on and noticed I was shipped main bolts not head bolts so I sent those back (FedEx overnight) and should be getting the head studs hopefully by Friday.
Again, will post pics soon!
Old Jul 16, 2009 | 07:10 AM
mrfinch's Avatar
Block looks in good shape....
Did you go with the ACL after all or the OEM bearings? What CR on your pistons did you go with? A list of parts would be cool to see. I only mention because I'm doing a rebuild on my B18C1 and I too am going 81.5mm. Also, are you sticking with the stock head?
Old Jul 16, 2009 | 10:40 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Old Jul 17, 2009 | 07:26 PM
went with the ACL due to cost ... doing this on a budget and yeh, sticking with the stock head.
here are some pics ...
crank in place after bearings and thrust washers put in ...
mock up ...
rods going in ...
some pics of the head
and intake manifold ...
Old Jul 17, 2009 | 08:21 PM
Vietnamese!
Nice work.
Any pics of the shell that you bought?
Old Jul 17, 2009 | 08:25 PM
rhymeshark916's Avatar
I'm doing a b18c1 build as well. My head is at the machine ready but I gotta drop my bottom half off along with my pistons. Question, are you sticking with all gsr parts on the head? Upgrading t/b, i/m, header, tune? I ask because I'm on a budget build but I would like to gain all the power I can so do I need those parts listed above?
Old Jul 17, 2009 | 09:04 PM
Originally Posted by ALLxMOTOR EG
Nice work.
it's a running car ... but barely, been giving me headache after headache with some overheating issues and not passing smog. Gonna get a new cat and smog it before I swap ...
here's a quick shot that I had on this computer
Old Jul 17, 2009 | 09:09 PM
yeh I'm staying as stock as possible, I wanna pass the sniffer and be reliable since it's just gonna be my daily driver.
I had to overbore it .20 over due to some rust on the cylinder walls from the engine sitting so long, otherwise I would have left it stock bore. It will have oem t/b, i/m but probably some aftermarket headers and full type-r exhaust
I'll get a parts list for you next week when I'm back home.
Old Jul 17, 2009 | 09:36 PM
Vietnamese!
^^ I like it clean.
Old Jul 17, 2009 | 09:49 PM
B18c1-China's Avatar
lol did you pick up that car on CL in the SF/north bay area? i could swear i seen it b4
Old Jul 17, 2009 | 09:53 PM
EK9r!der's Avatar
nice... keep us updated.
Old Jul 18, 2009 | 10:40 AM
picked it up in Camarillo (Ventura County)
^^ I like it clean.
thanks!
Old Jul 18, 2009 | 10:42 AM
will do! I just paid to get the replacement parts shipped ... the CORRECT ARP head studs should be here Wednesday
Old Jul 25, 2009 | 08:38 PM
got the ARP head studs in the mail the other day ... put those on today
here are a few quick update shots ... w00t!
quick mock up of the cams in after head bolts were put on ...
vtec solenoid and thermostat housing ... before and after shots of paint ..
more mock up ... was losing light, only worked on it for a little bit this afternoon ...
Old Jul 27, 2009 | 10:29 PM
need to order a cam seal, oil pan gasket and the valve cover gasket
got my Fidanza 7.5lb flywheel and Exedy clutch today
will post pics up later ... too tired
Old Jul 27, 2009 | 10:42 PM
jdhogg's Avatar
lookin good man you should paint it the same color. and nice golden retriever
Old Jul 27, 2009 | 10:52 PM
thanks man .. yeh its gonna stay the same color, maybe a little darker charcoal.
Old Jul 27, 2009 | 11:08 PM
jdhogg's Avatar
hell yeah isnt that thunder gray metallic?
Old Jul 28, 2009 | 08:35 AM
94LS_allmota's Avatar
good luck with the build........btw is that a 70 firebird
