removing PS and AC belt
Old May 26, 2009 | 12:54 AM
tekstyle's Avatar
Default removing PS and AC belt
is it ok to remove the PS and AC belt and just drive without it while leaving everything else on the car. I still have fluid in the PS.
Old May 26, 2009 | 02:48 AM
Dee's Avatar
Dee
Default Re: removing PS and AC belt
The non-flowing fluid in the closed system will cause a lot of resistance during low speed turns! Powering racks need to be vented with a enough fluid in the rack to maintain proper lubrication (loop line with a vent).
Is there a particular reason why you are doing this?
Old May 26, 2009 | 07:41 AM
tekstyle's Avatar
i was thinking about removing the belts fror a track session since its not that hard. So i was wondering if thatxwould work. How does a loop sys keep fluid from becoming static?
Old May 26, 2009 | 02:16 PM
boosted.da's Avatar
dont bother removing any belts, waste of time. Your driving will out do the belt removal. Its kinda like pulling your back seat to loose 4 lbs.
Old May 26, 2009 | 04:30 PM
tekstyle's Avatar
thanks for the tip. is there anything i can do to prepare? i am already doing my oil, changing brake pads, bleeding lines, replacing tires, and adjusting pressure.
Old May 26, 2009 | 07:05 PM
Mindgamez's Avatar
Spark plugs will help too and a good TUNE is always good can never go wrong with that. As for the belts theres no point but if u remove only that but the All the components of the AC and PS is almost 100pbs. I dont have either one and the PS took me a week to get use to but i love driving with out it now.
single_slam
Feb 23, 2014 05:40 PM
Integra4lyfe069
May 26, 2010 06:07 PM
Cold Fyre
Aug 10, 2006 05:33 PM
dip-set
Apr 24, 2003 09:13 AM
integranator
Mar 3, 2003 10:55 PM
