Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB
Old Aug 19, 2002 | 09:36 AM
ImportReview
Guest
Posts: n/a
Default Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB
THat is the type-R motor. Fat graph.
THis is a similar motor, but with LS crank.
Notice the Type-R crank just carries the HP longer.
I expect both these cars to hit 11's without too much problems.
THey are both, Import Builders Package 3 motors. With ITB's.
Jeff
[Modified by ImportReview, 10:36 AM 8/19/2002]
[Modified by ImportReview, 10:37 AM 8/19/2002]
Old Aug 19, 2002 | 09:44 AM
hungsteR's Avatar
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (ImportReview)
Wow that plot looks great. This is with the IB Package 3? I thought that was the CRV/Vtec package though.
Old Aug 19, 2002 | 09:45 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (hungsteR)
That would be fun on the streets
Austin's Avatar
Jeff...is there any way to see the entire graph...I'd just like to know what the entire curve looks like.
Thanks,
Austin
Old Aug 19, 2002 | 09:48 AM
ImportReview
Guest
Posts: n/a
When people spend this type of money for a motor, I let them pick what block they want to use.
Or what crank.
Some choose GSR/Type-R crank, some choose LS/CRV crank.
Either way, the block is sleeved. So its a waste to use a B20 block.
GSR or LS or in that case, Type-R.
Jeff
Old Aug 19, 2002 | 09:52 AM
hungsteR's Avatar
Thanks for the info. So besides the block, it's the exact same components of IB Package 3?
Old Aug 19, 2002 | 09:56 AM
D's Avatar
D
so, i'm confused.... you're calling a sleeved 2.0L (correct me if wrong) built NA motor a Type R motor?
i'd call it a built 2.0L... shrug...
D
Old Aug 19, 2002 | 09:57 AM
SuperTwinz's Avatar
itbs
Old Aug 19, 2002 | 09:59 AM
AllMotorMadness's Avatar
Expect to see both IB car's running in NHRA event next month @SearsPoint Raceway Sept.7-8th.
Doctor CorteZ's Avatar
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (D)
I think hes calling whatever crank is used the "motor"
I dont get it either , that many parts it isnt anything anymore
Old Aug 19, 2002 | 10:05 AM
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (C5_ALLMOTOR)
christ i want my block like that...those are sk2 stage 3 cams on both?
The type-r motor is using skunk stage 3 cams and the other is Jun 3's
Old Aug 19, 2002 | 10:06 AM
vtecvoodoo's Avatar
Future Texas Boy
The car I`m driving around right now makes 210 and it`s incredible. I can`t imagine 238 in a lighter chassis!
Ryan
Old Aug 19, 2002 | 10:14 AM
Dropspeed's Avatar
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (vtecvoodoo)
"Package 3: Hydro CRV/VTEC Dominator complete solution. "
Quoted from their site.
Old Aug 19, 2002 | 10:18 AM
ImportReview
Guest
Posts: n/a
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (Dropspeed)
People are mis-understanding.
The 238 graph is an actual TYPE-R motor.
Its just 2 liters. Its a real B18C5 block.
Is that what you all meant?
IB
Old Aug 19, 2002 | 10:19 AM
Suprdave's Avatar
Nice Graphs....
Suprdave
Old Aug 19, 2002 | 10:27 AM
TypeRod's Avatar
MAN MAN MAN!! Very nice graphs!! I emailed you ImportReview! I think I've found my motor builder! hehe!
Old Aug 19, 2002 | 10:28 AM
eviltwin's Avatar
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (Suprdave)
so, its like a crv-tec in with the effeiciency of b18c5 block. which means the oil lines are already there...
looks good, how about a 2.0L sleeved ITR block pulling that kind of horspwer and then throw a 200 shot on top so you can run the big boys hmm well i'll let you know how it goes...
Old Aug 19, 2002 | 10:50 AM
Sleeper's Avatar
Those are some killer numbers but do these motors make any power below 6k?
Old Aug 19, 2002 | 10:53 AM
SIINSI's Avatar
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (Sleeper)
I don't give a rats *** what block he is using, that is AWESOME power ANY way you look at it. Great work Jeff
Miguel
Old Aug 19, 2002 | 11:01 AM
Reelizmpro's Avatar
Those are impressive peak numbers but the damn engines are dogs below 6K RPM!!! wow. I guess that doesn't really matter if you drive with the RPM's up all the time. No too practical for everyday use though. Still impressive though
Old Aug 19, 2002 | 11:18 AM
gsrvx's Avatar
New User
Jeff, can you do that to my motor? I'll pay u back in ten years.
-Rod
Old Aug 19, 2002 | 11:19 AM
underrated99si's Avatar
Default Re: Here is the graph, 238 and 236 WHP, 1 is Type-R motor. IB (Reelizmpro)
Great #s Jeff I new you were a great motor builder from your previous graphs you have posted and your in person perfeshinalism at your shop
Big to the crew at Imoportbuilders
Old Aug 19, 2002 | 11:48 AM
ImportReview
Guest
Posts: n/a
There is no dyno graph for low end power, beause I didn't start the full throttle until about 5k+. Thats why its so steep early, because I just had goten on it.
These cars are daily drivers, and get excellent gas mileage.
IB
Old Aug 19, 2002 | 11:56 AM
simple4012's Avatar
New User
the blip at 93
00...? Tuning or timing problem or what? Just curious.
Were these runs made with the exaust on the car or off? Which header setup they have?
Which ecu setup they run?
Ill have to ask bob to post his dyno of his motor. 232whp/158lb-ft.......cars an animal........and those runs were made with cracked sleeves...will he be the first to hit 250 whp....?...????
Not if jeff can help it lol..
Looks good jeff.....out of curiosity how many mpg to cars with itb's usually get? Bob gets horrible mileage..but then again his junk isnt done being tuned...Nice though...very nice.
Tom.
[Modified by simple4012, 8:56 PM 8/19/2002]
Old Aug 19, 2002 | 11:57 AM
PreludeRacer023's Avatar
so theres no prob running the skunk2 stage 3s for daily driving?.im looking at the stage2s for my prelude..but looking for info on the stage 3s..peace
