I need a working horn!!!
I have a Spoon steering wheel and a momo hub for my R. Since I installed them both, I lost the auto-cancel for the blinker and my horn does not work. What is wrong with it? Why doesn't it work? Does anyone else have this problem?
i would also like to know. i have the jdm wheel and i ripped out the stock wires and tried to wire them to the jdm wheel but i'm retarded and donno what i'm doing. help somebody
there's a yellow connector which connect to the orginal steering......2 wire in it, the "ground" wire is the one for the horn. When you hotwire that ground wire to ANY metal part of the car === the horn will sound.
The next you need to do is make a thin "metal wire" at the bottom of the steering HUB and then make a connection to that ground wire(horn).
for the horn its just a minor wiring.
I also installed a momo wheel but my installer got the auto-cancel to work some how???
Although, I still have to use a seperate switch to activate the horn
I got an Integra hub, but for some reason I lose the auto-cancel....
crdcz03
Sep 10, 2020 09:23 PM
mahatma
10
Jul 11, 2005 08:18 AM
