suggestions on turbo d16
Old May 25, 2009 | 06:44 PM
chieft316's Avatar
New User
Default suggestions on turbo d16
i just got a 94 civic ex d16 with 175000 miles on it and i wanted to know if i should turbo it? due to the higher miles on it, i wanted to know if i should build the bottom end or what? I'm thinking about running a T3 T04E Turbo Kit, any suggestions i could use the help thanks!
Old May 25, 2009 | 06:46 PM
Unseen Racer's Avatar
Default Re: suggestions on turbo d16
not a good first post.
this is the technical forum.
post in the Forced Induction forum and you will get well knowledged people that will help you on your boost needs.
and please use the search. this topic has been covered several hundred times.
Old May 25, 2009 | 06:49 PM
jimmy o.'s Avatar
i would get another motor set aside (another z6) so if it desides to blow up i wouldnt do anything over 8 psi on stock internals
Old May 25, 2009 | 06:50 PM
PSI is irrelavent.
8 psi on a t3/t4 turbo is COMPLETELY different on a bigger or smaller turbo.
use power as your goals.
Old May 25, 2009 | 07:31 PM
turbohatch96y7's Avatar
i would definitly boost it then WHEN it blows just drop another 2-300 dollers for a complete motor and your good again
Old May 25, 2009 | 07:37 PM
mattyfo0z's Avatar
Do a compression and leakdown test and if everything is good, then you should be able to boost on stock internals for around 200whp if you'd like a safe daily driver.
If the compression test end up bad, then I'd try and get your hands on a fresh, low mileage d16y8/z6 with good compression all around to boost. They're easy to find pretty damn cheap for a full swap, so I wouldn't worry about spending too much.
Old May 25, 2009 | 07:50 PM
chieft316's Avatar
New User
thanks for the help ill get use to the site one day lol
GreaseyKidATtheParty
18
Feb 18, 2009 04:54 PM
wade
Sep 15, 2004 03:20 PM
2fastcivic
Jun 18, 2004 05:48 PM
Screamer
Nov 28, 2003 11:45 AM
00ITR725
Mar 27, 2003 08:30 PM
