rear sway bar on integra
looking to do a 22mm sway bar on my 95 integra rs, is the beaks kit good enough for a dd, dont really want the bling of asr brace and its not in anyways a race car. the car factorie has a 22mm front and 13mm rear, i just got front and rear gsr swaybars which are 24 front and 14 rear and figured i should upgrade all at once,
If you arent planning on doing any kind of serious driving, leave the bars on that you have now. If you want more rotation, just play with the air presure. Thats free, save your money...
To answer the question, yes absolutely Beaks is fine for the Integra chassis. Even the $20 BSQ kit works fine on the Integra chassis, even for cars that are occasionally autocrossed.
It can happen if you don't reinforce the subframe. But I know from personal experience that an Integra can handle a 22mm sway bar just fine with a Beaks kit or even with the simple BSQ kit.
thanks alot, thats exactly what i wanted to no, like i said i got the gsr sway bars for free and typer and gsr fronts are the same, so figured i can do the rear with beaks kit for under 200
Andrew 825SM
Jul 7, 2003 01:19 PM
