Brakes
Old May 25, 2009 | 12:00 PM
19Accord97's Avatar
Default Brakes
Hey Guys,
I am pretty sure that I have Akebono brakes and need to get them replaced asap. 97 accord 4cyl sedan
I plan on getting slotted Rotora rotors for the front with Hawk HPS pads. For the rear drums I plan on getting some mid level drums w/ a hardware kit.
Is this all that I need? The rotors are warped so I can't resurface them.
Thanks
Old May 25, 2009 | 02:32 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Brakes
If you're wanting to go with an upgraded drum in the rear, just do a rear disc conversion. Definitely worth the time and cash for the upgrade. You could also consider the Legend calipers while your at it.
Old May 25, 2009 | 03:45 PM
spoonfedcrx's Avatar
Default Re: Brakes
You can resurface warped rotors.
Old May 25, 2009 | 08:43 PM
19Accord97's Avatar
Default Re: Brakes
I'd like to do the drum to disc conversion but money is more than tight right now. Plus, I dont drive the Accord hard or anything, but would like the slight upgrade.
Well, even if you can resurface the rotors, my car has 112,000 miles and am on the original brakes and it def. requires more to stop.
But other than that, is that all I need?
Old May 26, 2009 | 06:25 AM
CRZ1's Avatar
Default Re: Brakes
It is difficult to remove 97 accord front rotor. If you can find a shop can do rotor resurface on the car and your rotor has enough width, it will be easier to do resurface.
If you plan to remove the front rotor, I guess it is better to change the rotor.
Old May 26, 2009 | 02:32 PM
19Accord97's Avatar
Default Re: Brakes
I just ordered Powerslot rotors and Hawk HPS pads for $248 shipped.
Old Jun 3, 2009 | 08:36 AM
19Accord97's Avatar
Default Re: Brakes
Just got them today
Do I need new calipers or anything?
Jim Dan
Honda Civic (2001 - 2005)
Apr 17, 2013 12:42 PM
Skatnshawn
Nov 10, 2012 07:44 AM
gtcali
May 19, 2006 09:54 AM
tomegun123
Aug 31, 2005 03:32 PM
bm3r
12
Jun 25, 2004 02:10 PM
