wtb 96-01 integra bseries parts
If anyone selling these parts, PM me. thanks!
gsr Aftermarket Intake
Valvecover breather
LS evap canister
Sparkplug cover
gsr valvecover bolts (8)
gsr water Temp sensor ( one that mounts on the upper rear of the block)
aftermarket fuel rail
& for a friend;
D16Z6 ECU
Idle Air Control Valve
Drag or Rota rims
will update later.
Valvecover breather
LS evap canister
Sparkplug cover
& for a friend;
D16Z6 ECU
Drag or Rota rims
will update later.
i have a brand new Mr Gasket Gsport PRO Billet 65mm throttle body check the link for info http://www.hondamarketplace.com/show....php?t=2589345
Valvecover breather - $10
Sparkplug cover - $20
gsr valvecover bolts (8) - which do you need? the Studs or the nuts? there are no bolts there.
gsr water Temp sensor ( one that mounts on the upper rear of the block). there are 2 sensors on the block, oil pressure and knock sensor. the only water temp sensor is on the thermostat housing.
Valvecover breather
LS evap canister
Sparkplug cover
& for a friend;
D16Z6 ECU
Drag or Rota rims
will update later.
Valvecover breather
LS evap canister
Sparkplug cover
& for a friend;
D16Z6 ECU
Drag or Rota rims
will update later.
thanks,...JJ
HybridKOOP
Northeast (Sales)
12
Feb 20, 2011 07:27 PM
JDM EJ1 95
Jun 19, 2007 11:33 AM
