HELP! Wiring Pinout for ITR Foglight Switch
Old May 24, 2009 | 07:48 PM
Eran's Avatar
HT White Ops
Default HELP! Wiring Pinout for ITR Foglight Switch
Ok, this is what I'm working with:
ITR foglight switch (round switch, 5-pin blue connector)
96-00 Civic foglight switch harness (5-pin green connector / three wires)
The civic harness goes into the headlight switch for power, and thus only has three wires:
Red/White -- 12v Power
Red/Yellow (or Red/Green) -- ??
Black -- Ground
Can someone tell me what each of the pins on the foglight does (#1-5)? Also, what the red/yel (red/grn) wire is supposed to do? I imagine it has something to do with switched 12v.
Here's an image I found, but does me no good on what each wire goes to (and the thread it came with was of little help because it utilized no stock wiring):
Some high-rez of a switch with all 5 wires.
http://hkc-speed.com/images/uploads/fog%20light2.jpg
http://hkc-speed.com/images/uploads/...ghtswitch4.jpg
Old May 25, 2009 | 02:02 AM
BlueIntegraBoy's Avatar
Default Re: HELP! Wiring Pinout for ITR Foglight Switch
I assume the cruise control switch and the JDM ITR foglight switch are the same internally.
Pin A: Fuse 14 (7.5A)
Pin B: Output
Pin C: Ground
Pin D: Fuse 30 (7.5A)
Pin E: Dimmer
Old May 25, 2009 | 06:42 AM
Eran's Avatar
HT White Ops
So all I would really need to work with would be output, ground, and dimmer ... since the foglight fuse is on the harness.
Old May 25, 2009 | 11:15 AM
Are you looking to use the JDM ITR switch with the USDM harness?
https://honda-tech.com/forums/acura-integra-type-r-8/how-use-jdm-foglight-switch-usdm-foglights-harness-1530877/
Old May 25, 2009 | 11:26 AM
Eran's Avatar
HT White Ops
Wish I could tell better which ones were going where. Looks like two of them are twisted over eachother ...
But that should really help. Thanks again for your help ... I'm all up on 6g's, but when it comes to teggy's and 5g's ... I'm still learning. Hopefully my sol will help me learn quicker.
Old May 25, 2009 | 11:36 AM
Use this pic to make out the colors/pins
Jknower
Honda Motorcycles
Sep 23, 2017 11:49 AM
VI Boost
Dec 18, 2008 01:54 PM
biochemist
May 1, 2008 06:34 PM
egblack94
Jun 18, 2007 06:39 PM
Forbesy
Jan 15, 2005 12:42 PM
