exhaust sizing for 200whp?
Old May 24, 2009 | 04:55 PM
matttegra's Avatar
Default exhaust sizing for 200whp?
Sup guys, i'm building my GSR with 11:1 CR CP piston, stage 2 Brian crower cams, camgears, dual valve springs, retainers, skunk2 intake manifold, CAI and a Tune with eCtune. My question is would i should look forward a 2.5'' header collector and a 2.5 '' exhaust system or should i stick with my 4-1 DC headers and a WS2 exhaust?? I would like to get close to 200-210 WHP. i've read that 200WHP cars are better with a 2.5'' collector and exhaust, but will i be able to push 200 WHP with my setup?? i wish, thats my plan.Thanks guys.
Old May 26, 2009 | 06:00 PM
matttegra's Avatar
Default Re: exhaust sizing for 200whp?
anyone guys, please i need to buy an exhaust soon
Old May 26, 2009 | 06:06 PM
OH_1fstgsr's Avatar
I am currenty running a DC 4-1 into my Comptech Exhaust. This set-up has been on my GSR for 9 years. I am now changing to a SMSP header and 2-1/2" exhaust to get me closer to 200whp.
Not sure if this will help you, but it is some input.
Old May 26, 2009 | 06:16 PM
matttegra's Avatar
ok, whats was your setup?? cams, pistons??
Old May 26, 2009 | 06:28 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
A 2.5" exhaust with no bottle necks should be ideal. T1R makes a good one.
Old May 26, 2009 | 06:38 PM
matttegra's Avatar
i was looking at the hytech,what you think? thanks guys
Old May 26, 2009 | 09:51 PM
RA429's Avatar
60mm is better than stock.
2.5" would definitely be ideal.
3" would be overkill.
Old May 26, 2009 | 10:46 PM
racebum's Avatar
2.5" is the standard. which header you choose will also have a very large impact on power. cat-less headers like the skunk2 use race oriented primaries that extend far further than the cat-able style. the jdm 4-1 or a modded edelbrock are popular cat friendly headers. still, they won't compete with hytech, rage or skunks
Old May 27, 2009 | 02:24 AM
matttegra's Avatar
i'm looking to go with the hytech twin loop exhaust and the hytech rage style header, its a replica of the the rage so it is more affordable, around 400$ compare to 900$
Old May 27, 2009 | 03:25 AM
OH_1fstgsr's Avatar
Exhaust
DC Sports 4-1 2-1/4" Header
SMSP High Flow Cat
Comptech Cat-Back Exhaust
Intake
RC Engineering Ported GSR Throttle Body 70mm>64mm
RC Engineering injectors w/clips 370cc
DPR Ported GSR Intake Manifold
AEM GSR Cold Air Intake
Block
USDM ITR Pistons (81.25)
USDM ITR Rods
Head
DPR Stage 5 Port ‘n’ Polish
Rocker Arm Balance and Lightening
ITR Valves, ITR Springs, ITR Retainers, ITR LMA’s
CTR Intake Cam Shaft
ITR Exhaust Cam Shaft
(Compression Ratio ~11.6:1)
This set-up currently rolls a Dynojet to 182/134.
Old May 27, 2009 | 07:41 AM
BaMBaM4002's Avatar
im a b20/GSR build and i hit 201whp with a DC 2" header --> Carsound hi-flo cat --> 60mm Skunk2 Exhaust.
i do however have a JDM ITR Header --> Hi-flo cat--> 2.5" piping w/ Apexi WS2 muff but i have yet to get the car re-tuned..
Old May 27, 2009 | 08:22 AM
EG6Boy702's Avatar
i ran a low 15 with just intake and 2.5 headers and exhaust b17/92 gs full interior
Old May 27, 2009 | 02:34 PM
matttegra's Avatar
ok, thanks guys, i think with hytech rage replica header and hytech twin loop exhaust (both 2.5'') i should be close to my 200 whp. Thanks guys
Old May 27, 2009 | 11:01 PM
Jimmyhf51's Avatar
let me know ur dyno number cuz im running about the same setup and too and im having quite a hard time getting to 200whp. but for my exhasut i ended up getting the skunk2 megapower R (70mm) piping or 2.75 i mean its loud but when u get used to it its not too bad.
Head
skunk2 stage 2 pro series cams
skunk2 cam gears
skunk2 valvetrain
UNported head
Block
11:1 cp pistons wit eagle rods
blocks guard
Hytech rep headers with test pipe all the way to my 2.75 skunk2 exhaust.
i got it rebuilt too so everything is fresh. this is off the top of my head i think im missing sum stuff
Old May 28, 2009 | 10:28 AM
jed1717's Avatar
Well to give you perspective, my setup is similar to yours:
B18c1 engine (81.5 bore), S2S1 cams (tuner), cam gears, ITR pistons, S2 IM, AEM CAI, stock header, stock cat, greddy exhaust (60mm). Since I live in CA, I had it tuned conservatively ( Hondata S100) to retain smoggability and made 193WHP/133TQ. Just as long you have a competant tuner, you should be able to make your 200WHP goal without spending an arm and a leg on exhaust products. Good luck!
Old May 28, 2009 | 12:33 PM
Jintegragsr97's Avatar
Damn, where did you tune at? Those are good numbers for your set up. Church tuned?
Old May 28, 2009 | 01:56 PM
jed1717's Avatar
Yessir
Old May 28, 2009 | 05:39 PM
matttegra's Avatar
i know it is expensive but damn it's nice and sounds great. I know i guy who do custom made exhaust 2.5'' mandrel bent with magnaflow satin performance muffler for 400$ but i know it will start leaking after one summer so i dont mind paying the price now, do it right do it once. i'll keep you guys up with the numbers, should be in a month or so. and Jimmyhf51 are your headers the big tube headers or the regualr headers with 2.5'' collector? thanks guys
Old May 28, 2009 | 08:49 PM
Jimmyhf51's Avatar
yea its the big tube design with the 2.5 collector to a 2.5 test pipe all the way back to my 2.75 skunk2 exhaust.
98_gsrteg
Aug 17, 2005 08:11 PM
PSU-TEG
Mar 12, 2003 11:05 PM
5-SpeedFreak
Jan 15, 2002 10:47 PM
