just installed skunk 2 coilovers and have some questions...
Old May 24, 2009 | 02:11 PM
98civdx's Avatar
Master Detailer
Default just installed skunk 2 coilovers and have some questions...
i put on skunk2 slip on coilovers on my civic with stuck struts, and i have questions about the ride height.
i have the front 2 almost as low as you can go have maybe 3-4 threads left, and its not as low as youd think, the kit said it would lower 3 in. and it doesnt look like 3 to me.
i got 185-65-14s and i can get 2 fingers in the gap, bewteen the fender.
i cut the bump stops in half like you supposed to and i put them in right and the shocks are aligned with the fork.
someone said someting that they take a couple days to setttle and once that happens it will be alot lower? is this true??
since its a 98 it doesnt matter if i switch the shocks around correct? becaue the fronts got switched.
thanks!
Old May 24, 2009 | 02:39 PM
jdmeh222's Avatar
Default Re: just installed skunk 2 coilovers and have some questions...
yes i would give it a couple of days for the spring to settle i also have skunk2 coilovers with about 3-4 threads left and my front mudguard are about 3/4 of inch of the ground
Old May 24, 2009 | 02:43 PM
98civdx's Avatar
Master Detailer
hmm thanks. i took mine off lol
Old May 24, 2009 | 06:53 PM
clean92ex's Avatar
yea it will take a couple days for the springs to settle. as for switching the shocks im not sure...
Old May 24, 2009 | 07:02 PM
sde780's Avatar
You can switch shocks, but the forks are definitely not switchable. I wouldn't go that low on stock shocks, they'll blow easy
Old May 24, 2009 | 08:28 PM
98civdx's Avatar
Master Detailer
the forks were not switch only the front shocks.
yea people were telling me about that, but i want it low but this is crazy, my friend has the same ones and if he puts them where i have mine hes tucking.
thank you......
lovelove
Suspension & Brakes
Jan 3, 2012 07:38 AM
czirr321
Oct 22, 2009 03:34 PM
D3vin
Suspension & Brakes
14
Apr 17, 2009 05:06 PM
whacking stick
26
May 25, 2004 03:20 AM
viet4gvtec
Jul 22, 2002 07:48 PM
