Benens Lower Tie bar + Stock sway?
Old May 24, 2009 | 01:04 PM
honda_coupe's Avatar
Default Benens Lower Tie bar + Stock sway?
Does a benens lower tie bar eliminate a sway bar on a Integra GSR? Or can you still keep the sway bar?
Old May 24, 2009 | 01:06 PM
VietSpeed's Avatar
Default Re: Benens Lower Tie bar + Stock sway?
A tie bar and a sway bar is two different bars. So the answer is no a tie bar does not eliminate a sway bar.
Old May 24, 2009 | 05:04 PM
i just wasnt sure if the sway bar had to be removed to install the lower tie bar.. like if the bar was in the way
FoUrOEiGhT
Sep 3, 2010 04:43 PM
94b16coupe
Suspension & Brakes
Jan 4, 2008 05:22 AM
Kyles ej1
Suspension & Brakes
Mar 27, 2005 12:17 PM
lowRIDAH
Jul 12, 2004 10:43 PM
Monkeydias
Mar 4, 2002 05:56 PM
