Classic Hondas All Pre-1988 Hondas.
Broken timing belt. Mind looking at my valves?
Old May 24, 2009 | 09:51 AM
mrfett3463's Avatar
Default Broken timing belt. Mind looking at my valves?
Long story short I broke my timing belt at 60-65mph and didn't turn off my car right away cause I couldn't figure out what was up. Well I pulled my head and found small marks from the valves on my pistons and my valves aren't closed. I have ever done any head work so I don't know if having space between your valves and head when their supposed to be closed is normal. They all have about the same amount of spacing so either their all messed up or its supposed to be like that. I'd love to hear any input you have. Thanks alot.
Old May 24, 2009 | 04:08 PM
cbstd's Avatar
Default Re: Broken timing belt. Mind looking at my valves?
Congratulations! You have bent valves.
Old May 24, 2009 | 04:47 PM
mrfett3463's Avatar
Ok, thanks that's what I thought I just thought it was kinda weird that they all got bent. I've only heard of people bending some valves not all of them so I didnt know. Well time for a motor swap. Thanks cbstd
Old May 24, 2009 | 09:03 PM
TheDarkRacer's Avatar
wut kind of motor/car. Ur pistons are fine to tell u the truth.
bent same valve on #1 piston twice and car still runs fine.
i'd say replace the valves, get a new timing belt + water pump and keep on keeping on.
Old May 24, 2009 | 10:16 PM
mrfett3463's Avatar
I got a 1985 Honda Civic with the 1.5L Carb in it. It's only got 98K on it. I thought about just pulling another head from the junk yard, it's 50% off this weekend so it might be worth a shot since I'm kinda strapped for cash at the moment.
Old May 25, 2009 | 05:34 PM
KWayRacing's Avatar
Might be,but who knows what kind of shape the exhaust valves will be on the used head? Very well might be a better deal though and then you have your original head still to take some time with when money is better. I like the less work and guaranteed results of just rebuilding your head. EIther head you need the same amount of gaskets/seals. The same amount of machine work i.e. clean/surface/ valve job/new stem seals. The only real difference is the cost of the valves.
Old May 26, 2009 | 10:44 PM
Just pull valves at a jy. Get a socket that fits over the retainers, smack with a hammer and bam! the valves are free to fall into the motor. from there just pull the head and pick the valves.
Old May 27, 2009 | 12:07 AM
aasarsak's Avatar
Don't do this unless you like doing the same job twice.
You don't know what kind of damage may have been done to the valve guides and the actual head itself. Not to mention hairline fractures in the piston, rods, crank, cylinder walls. you just never know what actually happened when those valves went crashing into your pistons while it was all spinning at 2000 RPM. Remember, this is aluminum you're dealing with here...
that head is not worth the gas to drive to a machine shop to have it rebuilt.
Just replace the whole motor. It will cost you less in the long run.
Old May 29, 2009 | 09:58 PM
KWayRacing's Avatar
This is not always true. You never know if a 25 year old motor in a junk yard is any good. You could leave the intake manifold in the car by doing the head only... no vacuum nightmares. Your original head would be to new or better spec, not 25 year old unknowns. However if you can source a "good" motor still leaving the intake in the car changing the entire engine might be a better all the way around alternative.
Old May 30, 2009 | 08:19 AM
mrfett3463's Avatar
I'm looking for a good motor right now or a swap. I don't think I'm just gonna fix the head or get a junk yard head, by the time I buy everything I'll be a couple hundred into it and who know if the junk yard head will be any good. I was thinking of swapping for the d16a1 for the cost and the simplicity of the swap but a B16 or B18 would be way more fun. As for the vacuum lines for the original engine, I have none I devac'd it like 5 months ago.
showmerider
Mar 17, 2010 11:32 AM
twentyhurtz
Sep 15, 2009 10:38 AM
gsr96cx
Aug 27, 2008 04:33 PM
guy_from_nerk
May 12, 2006 11:29 PM
V7echnic
Mar 14, 2004 10:05 AM
