Built turbo Honda civic
looking to get $7500 for it
the best way to contact me is email Snackman508@gmail.com
ill try to get back to you as soon as i can.
Im located in Elizabethtown PA
would consider a trade for 240sx s14 or s2000
99 SI wheels comes along with it
some info about the car
1998 Honda Civic DX Hatchback
about 125000 miles on the body
and showing 62000 now(12000 since turboed and rebuilt)
Rebuilt at 50,000 miles on the cluster
Engine – D16Y7
Professionally Rebuild Head with new valve seals (pressure tested)
Complete Rebuild Block(7-08) with all new seals
Block was bored .5mm over and honed
Vitara 75.5mm pistons (7-08)
Eagle H beam rods w/ ARP rod bolts (7-08)
NPR piston rings (7-08)
ACL rod bearings (7-08)
ACL main bearings (7-08)
ACL thrust washers (7-08)
ARP Headstuds (7-08)
Walbro 255 LPH Fuel Pump (7-08)
Greddy Turbo Timer (7-08)
HKS Style BOV (7-08)
FMIC (7-08)
Greddy 15g Turbo
Greddy Turbo Manifold
Greddy Downpipe
Motorola 2.5 Bar Map Sensor
DSM 450cc Blue Top Injectors
P06 Chipped with Neptune
RSR Exmag GT 2 Exhaust (Slip fit design, 100% Straight piping until muffler angle)
ACT HDSS Clutch
D16Z6 Intake Manifold
B16 Throttle Body
Suspension
Innovative Motor Mounts (7-08)
Ingalls Torque Damper (7-08)
Brembo Blank Rotors (7-08)
Hawk HPS Pads (7-08)
Omni Power Coilovers
Ebay camber kit (3-09)
Interior
ProSport Gauges. EGT, Wide band AFR, Boost (1-09)
CTR Style Door Panels
CTR Style Carpet (7-08)
Skunk2 Shift ****
EBay Short Shifter
CTR Shift Boot
Civic SI Cluster
5th Gen Prelude Front Seats
6000k HIDs head lights (1-09)
Suntek 35% window tint all around (10-08)
Exterior
New paint (10-08)
Spun 16” rims with goodyear eagle f1 tires (3-09)
Type R front grill.
7 color LED under glow
Also, currently dose not have AC
but has power steering
Currently its making 190 whp and 190 wtq at 12 psi tuned by Jon Kerr is at 14psi now, could probably up the boost a little bit and make some more power on the current turbo. The motor setup can easily handle over 300 hp....all you gotta do is upgrade the turbo and fuel system, get a new tune, and you will be runnin 300 hp reliably, people have pushed up to 450 hp more or less on the vitara setup
Engine – D16Y7
FMIC (7-08)
Greddy 15g Turbo
Greddy Downpipe
ACT HDSS Clutch
B16 Throttle Body
Suspension
Interior
Skunk2 Shift ****
EBay Short Shifter
CTR Shift Boot
Civic SI Cluster
Exterior
New paint (10-08)
Type R front grill.
robunicu
Sep 16, 2007 08:05 AM
