JDM 4-1 Headers collector question
Old May 24, 2009 | 07:12 AM
SQ is the SQUAD's Avatar
Default JDM 4-1 Headers collector question
so i got a parts car that had a jdm 4-1 header on it. i decided to take off my dc headers which where pancaked on the bottom. as i expected, nothing fits. but its cool because ia m throwing on a full magnaflow 2.5" exhaust setup. my main wuestion is what size is the collector on the jdm 4-1 header. a stock 2.5" flange i had did not fit even close. not sure if i should get a 3" collector. the parts car did have a ball type collector flange on it but it dident fit very good so i dident want to reuse it.
Old May 24, 2009 | 07:18 AM
Default Re: JDM 4-1 Headers collector question
i may of found my own answer
http://japaneseengines.wordpress.com...llation-guide/
so will i have to use a ball joint collector. i have about 6"of space from the header flange to my 2.5" high flow cat. so i want to add in a flex section
Old May 24, 2009 | 07:25 AM
ok i am going to order a flex section like this
http://cgi.ebay.com/ebaymotors/2-5-S...Q5fAccessories
but i may still need a larger ball collector. i just need to know what size ball collector works best with the jdm 4-1 header.
Old May 24, 2009 | 10:21 AM
racebum's Avatar
a flex pipe will work, so will solid tubing. if you keep the ball joint you might as well save the money on a flex pipe and just weld in a straight piece. if you do away with the ball joint then yes the flex pipe is needed.
Old May 24, 2009 | 11:16 AM
so what your sayling is the ball joint acts as a flex pipe. hhhmmm. but what size ball joint fits best. i know ill need a larger one then a 2.5"
Old May 25, 2009 | 04:49 PM
Old May 25, 2009 | 06:54 PM
racebum's Avatar
you must be measuring something wrong. the jdm itr header is a 2.5" collector. that means 2.5" pipe. how big the mushroom is doesn't count. you could run a jdm itr header and jdm cat and have the whole thing bolt right up you know.
Nacho169
Mar 30, 2003 05:03 PM
B19CivicHB
Aug 21, 2002 12:46 PM
rsx03
Aug 15, 2001 04:22 PM
