B16A 92-95 (SiR-II) From Hmotors
Old May 23, 2009 | 06:40 PM
szczerbanator's Avatar
Default B16A 92-95 (SiR-II) From Hmotors
I'm just curious what would be needed to put this into a 1994 acura integra, and also will this longblock work with a LS tranny?
Here is the link to the Motor:
http://www.hmotorsonline.com/shop/sc...age&item=30024
This is for just the longblock, so if it would work with a ls tranny. What else would i need for it to work?
Thanks in advanced!
Old May 23, 2009 | 07:07 PM
lsvtecwill's Avatar
Default Re: B16A 92-95 (SiR-II) From Hmotors
It should work and use the same mounts. It will fit on to the transmission. It is made to fit as it is the de-stroked version of an engine that goes in that car normally (GSR).
on a side note don't expect to be impressed by the power... A 1.6 in a DC with a LS tranny.... slowest way to have dohc vtec. just save the extra $600 for a B18c.
Old May 23, 2009 | 07:10 PM
Yeah good point. Well i currently have an auto B18b1, what would be the best way to speed it up a bit without boost, as it needs to be reliable for a daily driver...Thanks.
Old May 23, 2009 | 09:01 PM
bacnthalite's Avatar
Find a vtec head someone's selling and slap it on the top of your ls block....
you'll noticed tremendous gains, and it bolts up to your ls tranny-
Old May 23, 2009 | 09:24 PM
So i would have a auto ls/vtec wth 168k.....that doesn't sound too reliable to me.
Old May 24, 2009 | 09:22 AM
ok.... well, an automatic tranny is going to limit u no matter what setup u go with....
but if built right, an ls-vtec will last you as long as any other motor with an "H" badge-
168k is nothing if your vehicle was maintained-
__________________
Old May 24, 2009 | 10:33 AM
racebum's Avatar
just buy the $1599 b18c sir-g
NAturalEk9
Jul 23, 2009 10:50 PM
JoshChoi
May 16, 2007 09:26 PM
memorybox
Aug 10, 2006 06:16 PM
silverware
Nov 24, 2003 04:21 AM
89 CRX SI
Apr 16, 2002 06:46 AM
