What size bolts do you use to install the JDM 4-1 heat shields lower and upper?
Old Aug 19, 2002 | 01:24 AM
underrated99si's Avatar
Default What size bolts do you use to install the JDM 4-1 heat shields lower and upper?
Got all the goodies just need to get the bolts to hold them on but what size and how long and do they have to be able to take heat any help would be great
CHRIS
Old Aug 19, 2002 | 01:58 AM
Chubz's Avatar
Default Re: What size bolts do you use to install the JDM 4-1 heat shields lower and upper? (underrated99si)
12 mm i believe
Old Aug 19, 2002 | 03:43 AM
kenji's Avatar
25 Year Member
Default Re: What size bolts do you use to install the JDM 4-1 heat shields lower and upper? (GSRalph)
You can reuse the bolts that hold the heat shield on your stock manifold. 12mm head with 8 X 1.25 thread.
-kenji
Old Aug 19, 2002 | 04:07 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: What size bolts do you use to install the JDM 4-1 heat shields lower and upper? (kenji)
why even put the heat shield back on?
Old Aug 19, 2002 | 08:05 AM
eviltwin's Avatar
Default Re: What size bolts do you use to install the JDM 4-1 heat shields lower and upper? (RealTypeR)
to block the heat from circulating under the hood, therefore making underhood temperature lower which in turn helps the cooling effect and makes the air cooler and keeps the cars performance more effecient.
Old Aug 19, 2002 | 11:04 AM
Majuniors_no_vtecfu's Avatar
Default Re: What size bolts do you use to install the JDM 4-1 heat shields lower and upper? (eviltwin)
use plastic bolts......there the lightess
Old Aug 19, 2002 | 11:26 AM
Thanks kenji HOME DEPOT here I come
SHG_Claudio
10
Jul 16, 2009 06:47 PM
mynameizstitch
Suspension & Brakes
Mar 15, 2009 04:04 PM
civicandr6
Honda S2000
20
Apr 18, 2007 08:30 PM
TenaciousC
Sep 24, 2002 08:33 AM
TenaciousC
Sep 24, 2002 08:23 AM
