B18 Engine build
Old May 22, 2009 | 12:38 PM
VtecBlood's Avatar
Default B18 Engine build
I plan on startn with a fresh JDM B18 and buildin it up slowly. I want to start with headers, exhaust then work into the engine. After the simple stuff I want to do a Hondata S100 ecu swap with the stock. Ive been wondering what time into the build should I swap in Toda c camshafts? And if it would work with Hondata S100? Or should I just build up from lower spec cams and go up from there.
Old May 22, 2009 | 01:35 PM
jhammond_82's Avatar
Reject Papi
Default Re: B18 Engine build
what kind of hp do you want? what do you want to do with this car? what kind of budget are you working with? these are questions you shoud be asking yourself before planning on a build. as for toda cams, yes they are great, yes they perform well. but for the price of a set of them, you can sometimes put together a nice little turbo kit and have a faster ride than just with cams. have you considered forced induction of any sort? its not as expensive as you might think. especially if you are planning on doing the work by yourself.
Old May 22, 2009 | 04:41 PM
VtecBlood's Avatar
As close as I can to 300. I want a all motor build, and build it up slowly, Itll be a daily driver. Well until I have enough money to buy a seperate car. But I dont have the motor yet. Im just planning everything out. I like turbos but Im more bout all motor power.
Old May 22, 2009 | 04:55 PM
MyHotsh's Avatar
300hp on a all motor build is going to cost you alot... Hope you have deep pockets.
Old May 22, 2009 | 06:15 PM
Reject Papi
i had a friend on superhonda that did 250 all motor in his integra, he was almost at 4k before he had 250 na hp. and that was in a gsr. you may want to reconsider your hp goal.
Old May 22, 2009 | 09:09 PM
matzekm's Avatar
most na honda's run very high comp. and normally need to run race fuel just to run correctly. you get anything over 12:1 compression and not even hondata can save you from running race fuel. I don't think you will get that kind of hp just running cams and tune. Turbo is realiable (if built right), and can get well more than 300 if needed
Old May 22, 2009 | 09:33 PM
Bunger's Avatar
Boost is the most reliable path to 300 HP, and probably the cheapest, unless you want to consider nitrous.
Old May 22, 2009 | 11:25 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Search button, make friends with it, the older it is the better the info.
Old May 23, 2009 | 12:38 PM
VtecBlood's Avatar
Thanks guys. 250 hp is about right for what I want, I dont want to race fuel though. But I am thinkin about a nitrous setup. Im thinkn bout considerin turbo. But I really like keepin it "All" motor. Its not goin to be all at once, Ill build on as I go.
Old May 23, 2009 | 12:56 PM
VtecBlood's Avatar
Also I plan on using Itbs. Would I be able to run nitrous on a itb motor properly?
Old May 23, 2009 | 06:31 PM
matzekm's Avatar
I live in the wichita area also. a good person to talk to about this would be ray down at fuzion works racing there in wichita. Very good tuner, knows alot about honda's
Old May 23, 2009 | 10:18 PM
Maverick's Avatar
Team Purple
300 ponies on NA is a stretch. might as well boost it and save a couple Gs.
but maybe he has money talking about Toda cams and all..........
Old May 24, 2009 | 11:24 AM
VtecBlood's Avatar
Ill have to look into that. Thanks. Does he know how to tune hondatas? jw
Old May 24, 2009 | 04:49 PM
civic_jones's Avatar
hey i know you really want to keep it NA but for a 300 HP goal thats an accomplishment, i would suggest building the motor up some like you wanna do, internals/fuel/computer all that fun stuff and then consider forced induction, on a B18 you can run 5 LBS of boost all day long and not have a problem, especially if its built, just remember tuning is one of your best friends when it comes to building your motor, GL with your build.
Old May 24, 2009 | 07:11 PM
VtecBlood's Avatar
Thanks man. Im thinkn bout considerin boost. But if I went boost Id want raise my goal to 400-500 hp.. Does anyone know if I could safely run itbs with nitrous. A 50 or 100 shot??
Old May 24, 2009 | 07:39 PM
Ass$nyper's Avatar
Why couldn't you?
the shot size depends on your tune and the guts of the motor, fuel as well.
Old May 24, 2009 | 08:09 PM
VtecBlood's Avatar
Originally Posted by ***$nyper
Why couldn't you?
Well Ill be runnin on regular fuel, maybe highest 92.
Old Jun 15, 2009 | 09:56 AM
bulz's Avatar
New User
is motec advisable on NA setups? thanks
Old Jun 15, 2009 | 10:25 AM
Ass$nyper's Avatar
Still do able.
Joey B 18C
Aug 3, 2004 11:19 AM
2001silvergsr
Nov 18, 2003 07:05 AM
Unknown Member
20
Jun 8, 2003 11:59 AM
MJ23FE
Feb 25, 2003 08:00 PM
neumonik
Feb 20, 2002 12:59 PM
