b18c1 no butterflys.....obd1 b16 ecu???
just a quick question. how good will a obd1 b16 ecu run a gsr w/o the butterflys? i ask cause i have a b16 in my 96 coupe now and just picked up a gsr finally. and i wana get rid of them. got whale dong intake, kamazki header, and a total custom 2.5 exhause with no cat. i was hoping 2 not have 2 fork out more cash 2 chip the ecu. but if so im in mid md who is good and how much????
yea with a stock manifold you want your secondaries to open up...the pr3 will work but your better off running a chipped p28 if your going that route..as for chip companies, there are tons of them out there. do your research because your most likely going to have to send your core out anyway....i mean in the past ive used ebay "spoon" chips and they worked just fine just no rev limiter
ok thanks guys i was looking at the phearable.net chips and i think ill go that rout. just dont wana send out ecu 4a week if i can get by on the stock p30. but thanks again guys.
yes sir. i have a p30
and i tookk out the butterfly 2day and cleaned out the manifold. holt poop was it dirty. lot of carbon and oily grease. carb cleaner did work son. im in the process of port matching the plemuns. and the intake as well as the tbody. hope its all worth the time
yeah well i took out the butterfly section lastnight. and port matched the upper and lower parts of the intake manifold. going 2 work on the intake manifold gasket section 2morow.
