ORIGINAL 91 CRX si EATING GAS
Old May 21, 2009 | 10:35 PM
maurotolomei's Avatar
New User
Default ORIGINAL 91 CRX si EATING GAS
I thinks it running too rich or something because its real boggy up to about 4000 rpm and then some power kicks in. Its the original 1.6 si motor with new pistons and rings and 145,000 originally on it. I put about 3000 miles on it so far and it used to get a little bit over 300 miles on a tank. Now its getting about 190+/-. Please help anyone....glad i found this site but did not find any previous threads with a situation like mine. Its not flashing any codes either.
Old May 21, 2009 | 10:47 PM
SingleCamin's Avatar
Default Re: ORIGINAL 91 CRX si EATING GAS
regular tune up !..
Old May 21, 2009 | 11:39 PM
New User
whats a good tune up consist of then? i think they may have not plugged something back in but i'm not sure what. like i said it takes off at 4000 rpms but no low end power like its being flooded?
Old May 22, 2009 | 01:15 AM
pullin crx hf's Avatar
When I did my zc swap I got 10Mpg. Yes 10mpg! I had a bad ecu. Not saying you have the same problem but if you have another ecu try it. I now get about 200 miles to 6 gallons of fuel. Also +1 on the tuneup
Old May 22, 2009 | 06:38 AM
dacrxguy's Avatar
pcv
fuel filter
correct tire pressure
dizy cap rotor wires plugs
valve lash
and dont drive like a jackass
Old May 22, 2009 | 09:17 AM
mitsubishiv5's Avatar
id check to see if your leaking oil, not having enough oil can make your car eat gas. id also check for clogged injectors, ecu codes, and make a tuneup as this may help to solve other problems. If the problem still exists after that then its something else.
newuser333
Nov 29, 2006 02:37 PM
easynowrudeboy
29
Sep 26, 2006 10:15 AM
KingKhong
Jun 6, 2005 11:33 AM
CRX Si
20
Sep 16, 2004 11:15 PM
RacerBoy
Oct 2, 2002 03:07 PM
