help with del sol stock wheel stuck on hub
Old May 21, 2009 | 09:31 PM
whatsreallygood's Avatar
Default help with del sol stock wheel stuck on hub
so I tried to replace my front passenger side stock wheel/tire on my 94 del sol and cant get it off, it seems like its rusted on the hub or something, tried bangin wheel with mallet and still wont come off anybody else ever have problem like this? any suugestions would be kosher
Old May 21, 2009 | 09:40 PM
PhatFactory's Avatar
Default Re: help with del sol stock wheel stuck on hub
Try using PB blaster (wd40 ect.) on the hub and bang the back on the rim (rotate rim after each hit). Remember to have at lease one lug on, just a couple thread so the rim don't go flying. Put your back in to the bangs or hit the gym.
Old May 21, 2009 | 09:42 PM
supersteven's Avatar
When I have this problem at work I hit the tire from the back with either a board or if it's real bad I'll roll the jack into the back of the tire HARD if the car's high enough. That's just me though. I'd have to be there.
Old May 21, 2009 | 10:16 PM
D16vtecfreek's Avatar
New User
I usually tape a wooden block to the top of the rim and then hit it with a large sledge.
Old May 22, 2009 | 04:53 AM
91blackEF's Avatar
if your changing it on the ground i just sit my fat *** down and give it a swift kick with my heel seems to do the trick but if all else fails you can try heating up the center to expand the metal.
Old May 30, 2009 | 07:59 AM
So did you ever get the tire off? Did you beat on it like a **** star?
BLUIZE256
Northeast (Sales)
Nov 5, 2008 05:51 PM
sohctodohc
Sep 3, 2006 06:18 PM
ahloung
Northern California (Sales)
Mar 12, 2006 09:41 PM
Will SR20
Oct 27, 2004 05:57 AM
maxxdout
May 2, 2002 07:51 PM
