b16 pistons in gsr
Old May 21, 2009 | 07:42 PM
SurferDude905's Avatar
Default b16 pistons in gsr
I just cracked a piston in my b16 and I'm alittle confused on what to do. This motor was just a budget build to gain all the knowledge I could when going boost. I'm confused on whether I should just replace with stock pistons or buy low comp forged pistons.
I'm building a gsr for next year that I wanted to spend the money on and I was curious if I bought 9:1 pistons for the b16 would they work in the gsr?
Thanks
Old May 21, 2009 | 11:46 PM
rotten's Avatar
Default Re: b16 pistons in gsr
B16A and GSR have the same bore size (from the factory anyway), so yeah they are pretty much interchangeable.
Your C/R won't be the same though due to the stroke being different.
Old May 22, 2009 | 04:41 PM
Could I swap stock gsr pistons into my b16 and my b16 rods without milling the rod to fit?
Is it that easy? Or will there be machining involved?
Old May 22, 2009 | 09:12 PM
rotten's Avatar
The B16A and LS rods are wider than the GSR pistons, so yeah you'd have to narrow the small end a bit.
I think that USDM B16A's may have the same width rods as the GSRs--but I don't think so.
But other than that, the GSR pistons will fit in the B16A, but that configuration will drop compression considerably.
Old Jun 13, 2009 | 06:42 AM
Rheg6's Avatar
the difference in his case wont be the stroke.. its the dome of the b16 pistons that is going to bump the c/r of the gsr up .. i see this too much man people just throwing wrong information at ppl .. if you dont know dont say it .. it only causes confusions
SurferDude905
May 21, 2009 12:46 PM
ghostskinner
May 29, 2005 04:55 PM
hondaeg8
Mar 19, 2005 12:37 AM
JDM23
Nov 21, 2003 04:08 PM
