1989 Civic sedan shell ready for d16z6 turbo 600obo
Old May 21, 2009 | 05:53 PM
turbo_d's Avatar
Default 1989 Civic sedan shell ready for d16z6 turbo 600obo
----LOCATED IN SMYRNA, TN----
PRICE DROP!!!!!!!!!!!!!!!!! 400 dollars!!!
1989 Civic sedan shell. 5 speed. Its flat black right now, because I was in the process of actually painting it, but I ended up getting a different shell to put my motor in. I had a boosted d16z6 in it, and just pulled it out last night. It comes with the obd0 to obd1 conversion harness, and it has a d16z6 fully tucked wiring harness that goes through the firewall in the middle instead of the left side, where it is stock. It is wired up for vtec, 4 wire o2, and multi point conversion. A d16z6 would be a direct bolt in plug and play as it sits. It has a walbro 255lph fuel pump in it. The headlight wiring harnesses are tucked under the fenders, the fuze box is in the glove compartment, and the battery is the truck. The bay is really tucked, and really easy to work on. I took my motor out in like 2 hours.... It also comes with d series mounts with prothane inserts. They are really stiff. The cabin is clean, there are no tears in the seats, or burn holes. It has a autometer air/fuel guage, and sunpro 2 5/8" tachometer. The car also will come with a f1 racing stage 3 racing clutch, might need a new disk, but I had it in my car and it pulled good. The hood has a big dent from the bottom where my wastegate was. It will also come with a d15 5 speed tranny. It has mounting brackets for the front mount intercooler. The front bumper is on the car, I just had it off when I took the pictures. I have the clear title for the car in hand.
If the shell gets sold, I will have this stuff for sale also:
d16 cast iron t3/t4 manifold................$50
d16 custom 3" downpipe....................$60
greddy knockofff blow off valve..........$50
manual boost controller.......................$20
Motorola 2.5bar map sensor...............$15
Can work something out if you want some of this stuff with the car.
Stuff that is for sale with out the shell sold:
p2p manual 98' civic ex ecu.................$70
D16z6 alternator....................$30
D16z6 starter........................$30
D16y8 cast aluminum oil pan...............$20
d16y8 valve cover............................$25
Let me know if you are interested: stojicboy@hotmail.com or 615-223-0409
Picture Links below
thanks, David
Old May 21, 2009 | 06:50 PM
Black-Ty [EG6]'s Avatar
Default Re: 1989 Civic sedan shell ready for d16z6 turbo 600obo
bump
Old May 22, 2009 | 04:48 PM
turbo_d's Avatar
"ek all day"
I agree, thats what I'm swapping the d16 into. And thanks for the bump dude.
Old May 23, 2009 | 01:52 PM
turbo_d's Avatar
bump
Old May 24, 2009 | 09:34 AM
turbo_d's Avatar
anyone?
Old May 24, 2009 | 01:03 PM
killakalipoph's Avatar
bump because i want this shell...gl with it
Old May 24, 2009 | 07:41 PM
turbo_d's Avatar
thanks for the bump
bump
bump
bump
Old May 24, 2009 | 07:56 PM
92teginsc's Avatar
do you have any interior parts?
Old May 26, 2009 | 12:25 PM
turbo_d's Avatar
extra, or on the car??? I have all the interior parts that come with the car, but I dont have any extra stuff. Bump
Old May 29, 2009 | 05:41 PM
turbo_d's Avatar
400 dollars
meric0786
Nov 21, 2008 08:12 PM
memorybox
Jul 4, 2006 10:06 AM
posterfee
Jan 12, 2006 07:54 PM
craigie
Apr 27, 2003 08:44 PM
