honda/acura civic si gsr b series MANY parts pickup only prices are LISTED!!!
Old May 21, 2009 | 11:36 AM
maxum17ft's Avatar
Icon5 honda/acura civic si gsr b series MANY parts pickup only prices are LISTED!!!
honda/acura civic si gsr b series parts:
$190-RC Engineering 550cc saturated injectors, used for 12k in my SI, upgraded to 680's for 21psi, theyre mint
$175-em1 civic si seats out of my car. mint except for one tiny tear in the drivers bottom seat that u dont even notice.
$70-t3/t04E turbo. only has 5k miles and is mint but the compressor sucked up a piece of plastic from the air filter and ruined the cold side fins. just needs the compressor fins. no play.
$125- FULL SET of gsr grey leather seats.
$120-b16a2 '00 civic si distributer
$40-jdm gsr vtec solenoid setup
$90-usdm b16a2 '00 civic si throttle body with perfect sensors
$50-stock b16a2 cams
$85-mint b16a2 valvecover. factory wrinkle finish is perfect.
$20ea.-(2)oem spark plug cover b16 or gsr
$15ea.-(2) oem gsr/b16a water pumps, low miles
$40ea.-(2) jdm gsr/b16a oil pumps, no ckf sensor since jdm, need chipped ecu
-(3) bare jdm b16a blocks, $85- 1 needs honing, comes with crank, $65-one needs boring, the last is good for core fee-$50
$25-'00 civic si lower drivers side ac bracket mount
$20ea.-(2)obd1 upper driver side mounts b-series(3 bolt mounts into block)
$30-ARP rod bolts for d-series, 8mm ones, brand new
-(3) b16a2 timing belts, all under 15k miles, $10 ea.
$15ea-drivers side '00 civic si tail lights (2) trunk one body
$15ea-random obd1 b-series mounts
$20ea-(2)gsr/b16 factory oil catch can setups
$20-(2) gsr crank pulleys with key and bolt.
$25-(2) oem tstat housings with water pipes
$50-b16 crank, mint
$40-b16 crank, one rod spun, still usable if repolished. did require largest bearing, now once polished will just step down a bearing color or two, ask for more info.
$10ea- jdm gsr oil filter water cooled housings(factory oil coolers)
$100-obd1 vtec distributer not sure if b16 or d16
$100-JDM high compression b16a pistons on b16 rods
$30-stock gsr fuel injectors, 240cc obd2
$40-GSR/B16 halfshaft
$40-stock b16 headers with downpipe
$30-stock gsr header
$40-stock 2000 civic si cruise control unit with acc's
$55-stock gsr butterfly secondary controller obd2
$15-stock 1.7 bar map sensor for obd2 bseries
$50-oem 2000 civic si front bumper, holes cut out for fogs, in primer
$40-6000 kelvin h4 hid kit make offer, has cracked bases but still works flawlessly!
$35-stock b16a2 fuel injectors obd1
$50-exedy stage one clutch kit for B-series, used, will need new clutch disk soon but the rest of it is great, was used in my 400whp si and couldnt handle the power. replacement disks are very cheap, its well worth 50 bucks for the pressure plate.
$35ea-(3) knock sensors for b-series
$30ea-(2) oil pressure sensors
random other sensors available, ask...
$5-factory gsr oil filler cap
$100-'98 civic ex power steering rack complete, same as '00 civic si.
a list of other stuff i need to sell:
$50-nextel i880 bad screen, its upside down
$40-nextel i710 mint
$60-nextel i850 mint in box
$40ea-(2)hoosier slicks- 23x9.5x15 used for 3 passes, 85%
$25ea-18x8" rims no tires only have 2
$90-mtx thunder 7500 series sub in ported box
dsm parts:
$45-brand new RRM CAS harness to convert 7 bolt to 6 bolt. retails for $80
$175-real mitsubishi evo 3 big 16g with o2 housing. ported and comes with ss oil feed and coolant fittings.
$8ea-interior plastic pieces, grey in color, door, (3)hatch cover, rear pieces
$50-stock 4g63 cams
$20ea-dsm valve covers.
$25-95 awd turbo cruise control unit
$100-fwd turbo act steel streetlight flywheel, used for 200 miles
$10-2g wiper arms
$40-stock dsm side mount intercooler
lancer parts:
$50-evo 7 abs plastic wing
$40-evo 7 extreme side skirts(fiberglass)
shoot me a pm if interested or if you want pics
Last edited by maxum17ft; Jul 22, 2009 at 07:59 AM. Reason: added more stuff!/updated sold items
Old May 21, 2009 | 11:59 AM
G0TB00ST's Avatar
From: ON A STREET NEAR YOU BREAKING TRACTION ON ALL 4 WHEELS!
Default Re: honda/acura civic si gsr b series MANY parts pickup only prices are LISTED!!!
IM INTERESTED IN THE THERMAL FOR CIVIC COUPES... PLEASE PM ME SOME PICS... OR EMAIL THEM TO BOOSTINAT30PSI@AOL.COM. ALSO CONDITION PLEASE
Old May 21, 2009 | 12:52 PM
maxum17ft's Avatar
just shot you an email! its mint.
Old May 23, 2009 | 03:18 PM
maxum17ft's Avatar
also forgot to list these:
both drivers side tail lights(trunk and quarter panel), 50/50 oem '00 si, $30 for both.
also have another drivers side trunk tail light, $10.
Old May 28, 2009 | 07:15 AM
maxum17ft's Avatar
bumppp, added more stuff to top of list people!
Old May 29, 2009 | 09:51 AM
maxum17ft's Avatar
tttt, sold a few things, a few more are sale pending, make offers people, i want room in my garage!
Old May 29, 2009 | 08:12 PM
SeanZ0r's Avatar
bumpp!!!
Old May 30, 2009 | 08:21 AM
maxum17ft's Avatar
thanks for the bump!
Old May 31, 2009 | 10:30 AM
maxum17ft's Avatar
sold a few things bumpp
Old Jun 1, 2009 | 01:48 PM
maxum17ft's Avatar
bumppppin it uppp
Old Jun 2, 2009 | 07:50 PM
DC4Marco's Avatar
still have the front bumper? what color is it?
Old Jun 9, 2009 | 01:48 PM
maxum17ft's Avatar
front bumper is SOLD, sorry bro.
bumppppin it up. been busy but how bout everyone make some offers on stuff, make any offer, ill review it. i need room in my garage, i have a 3 stall garage with 2 '00 si's and a 350z and i cant walk through it, help me out.
Old Jun 17, 2009 | 12:10 PM
maxum17ft's Avatar
bumpo, added gsr leathers and some dsm parts...
Old Jun 18, 2009 | 12:03 PM
G0TB00ST's Avatar
is the thermal available still?
Old Jun 21, 2009 | 08:55 AM
maxum17ft's Avatar
the thermal is sold!
Old Jun 24, 2009 | 02:14 PM
maxum17ft's Avatar
bumpp
Old Jun 25, 2009 | 05:39 AM
maxum17ft's Avatar
bump, updated list, added stuff to top!
Old Jul 3, 2009 | 07:45 AM
maxum17ft's Avatar
bumpo
Old Jul 3, 2009 | 10:40 PM
Wyatt87's Avatar
Interested in gsr flywheel and clutch. shipped to 33326. THanks
Old Jul 9, 2009 | 09:36 AM
djkrisg's Avatar
interested in stock b16a2 injectors. are these obd2? are the clips available?
Old Jul 9, 2009 | 12:00 PM
cvcrcr99's Avatar
Bump!! That's a good price on the GSR leathers!
Old Jul 10, 2009 | 03:39 PM
maxum17ft's Avatar
sorry wyatt87, pickup/delivery only. i dont have paypal.
djkrisg - the stock b16a2 injectors are obd2, i have obd2 clips laying around somewhere off my 2000 si. so they have the clips too.
cvccr99 - thanks, i know its a good price, and i would actually take 125 for em all. i started painting cars again and i DEF dont have the room in my garage for all these parts!
Old Jul 17, 2009 | 04:22 PM
maxum17ft's Avatar
bumpp, taking offers on everything, alot is sale pending, but make offers, PICK UP ONLY!
Old Jul 17, 2009 | 04:26 PM
jtaylor16's Avatar
pics of the 18x8 wheels send to: taylor0415@comcast.net
Old Jul 17, 2009 | 04:42 PM
egturbolsvtec's Avatar
does the vtec solenoid work and do u have any pics
