Dirty Integra Lights...
Does anyone have this problem....The head lights seem to have this film over them...they just dont look clear as tehy use to. Is there plastic cleaner or polish that i can get to clean them?
Here is a picture..you can sorta see the film.
[Modified by Cramerox, 11:19 PM 8/18/2002]
Follow this process.... worked great on my 95 DC (r.i.p)
Materials you will need:
1. 3M 1000 grit sand paper.
2. any type of car polish.
3. any type of car wax.
4. a tupper-ware bowl filled w/ water ( if you know about wet-sanding ... u see where im going w/ this)
Procedure:
1. Remove you headlights off the car .... Yes we know takn' off the bumper is ever stonners nightmare!
2. Fold you 3M and wet it in the tupper-ware bowl and start sanding your headlights in a circular motion for atleast 10-15 min. on each light. Feel free to wet the sand paper time 2 time.
3. Assuming you're done w/ all the lights you will notice that all your headlights look like ****. Don't worry you have just done the 1st step.
4. Now time for the polish. You want to use the polish 1st since it is somewhat abrasive. Polish each light for about 5 min. each.
5. Asumming you are done polishing all the lights, Time 2 wax. It is the same process as the polish.
6. Put the **** back on your hooptie
and voila' you lights look brand new .... and you saved atleast $200 bones ..... and if you got the cash get some new bulbs
____________________________________
Hope this is sufficent enough!
Procedure:
5G_Vtec
Mar 22, 2007 11:27 AM
