Tach jumps / bad gas mileage
Old May 21, 2009 | 06:16 AM
vsm_EJ6's Avatar
Default Tach jumps / bad gas mileage
Before everyone jumps on me for searching, I just want to verify if this is the issue. I don't feel like looking at my car for a week when I send my dizzy back to distributor king for an exchange just to find out its not the ignitor.
Overview: H22 --> EK, I/H/E
Last week I installed a new intake / stock throttle body / header. TPS is not adjusted yet, but I'm not throwing any codes.
I installed the header, drove to the muffler shop open header and dropped the car off to get the header welded up. I went and picked the car up, and it wouldnt start. Turned out to be bad plugs. (6,000 miles old!) I was still getting 240miles to a tank though.
I drove my car for a day, was absolutely fine. Hit vtec, pulled hard.. no issues. During my autox this weekend, I noticed my tach going crazy above vtec.
So driving home, above 5000 rpms, my tach jumps up 1000rpms, then down and up and down all the way to 7800rpms. I have no issues before 5000rpms, the car does not bog, I have no codes.
I checked all the grounds. They're good.
I filled my car to about 1/2 a tank, and in the matter of a day its back down to 1/8th tank with a total of 25miles driven...
So would a bad ignitor cause bad gas mileage & the tach to jump ONLY after vtec engages?
Thanks.
Old May 25, 2009 | 06:14 PM
vsm_EJ6's Avatar
Default Re: Tach jumps / bad gas mileage
BUMP! Anyone? I don't wanna stare at my car for a week if its not the dizzy lol.
Old May 25, 2009 | 07:50 PM
Slopoke's Avatar
Jumping tach is one of the tale tell signs of a bad coil.
Not even two weeks ago I was experiencing the exact same problems. No issues at low rpm. At high rpm the tach would jump all over the place.
Put a new coil in and no more problems.
Old May 25, 2009 | 07:53 PM
vsm_EJ6's Avatar
Thank you. Thats what I needed to know. Every issue I found, it was through the whole entire RPM range.. not just high rpms. If anyone else has any insight, itd be appreciated. I'd like to feel 100% confident that when i get it back, my car will be 100% again. lol
Old May 29, 2009 | 10:49 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
i concur
i wish i would've known this awhile back, it would've sure saved a bunch of money and time!
c0d0r
Nov 4, 2007 01:49 PM
saikouEF8
Jul 5, 2006 03:06 AM
stRodda
Jun 8, 2005 08:03 AM
5thgenCory
Jul 18, 2004 12:08 PM
IWearMyKswiss
17
May 20, 2004 09:00 PM
