time to get b16 running right again, need help
Old May 21, 2009 | 05:40 AM
Meyerman015's Avatar
Default time to get b16 running right again, need help
Hello everybody!
like the title said, I want to get my b16 running like it should be. My determined issue due to burning oil has been piston rings. Instead of replacing just the rings, and then shortly replacing other stuff, i'd rather get the most likely stuff out of the way. I'm just going to take it into a shop, seeing as i need this to be done as quick as it can be and im willing to admit my level- novice.
So, question is- What all do you suggest I have done, and if you have any ideas on a price that'd be cool. If your in the madison area a suggestion for a shop would be cool too. I got a place in mind, but curious to hear others opinions.
Old May 21, 2009 | 05:58 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: time to get b16 running right again, need help
do it yourself and learn how. i did
Old May 21, 2009 | 06:41 AM
I really want to, its just that I have to make it to school and work almost every day of the week. so I kinda need it done quickly and accurately. If i can convince my girlfriend to let me take her car or something, then i might be able to. But, regardless- i need some ideas as to WHAT i should have done.
Old May 21, 2009 | 06:53 AM
redlinetuning's Avatar
If you know you need piston rings, you'll need at least a hone.
Budget?
Taking it in won't be cheap, but a reputable shop that knows what they are doing will be glad to help you out.
List of minimum things to consider:
Front/rear main seals
Rod/Main bearings inspection/clearances checked
Crank balancing
New rings, obvious
Piston/wrist pin inspection for play
ARP nuts/bolts/studs
valve lash
new oil pump
new water pump
new headgasket (oem will be fine)
new timing belt
Old May 21, 2009 | 11:07 AM
redlinetuning- thank you, i was kind of thinking about some of that too. that helps out a lot!
Old May 21, 2009 | 11:29 AM
sure.. no problem.
nixcite
Jan 16, 2009 03:43 PM
vtecpsyco
Dec 4, 2005 09:36 PM
egvtec
Jul 6, 2005 07:17 PM
