Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Honda civic 2006 coupe..bypass lighter to stay on
Old May 20, 2009 | 05:44 PM
rock88's Avatar
Default Honda civic 2006 coupe..bypass lighter to stay on
Hi there ,
I have a 2006 honda civic coupe ..i have 2 power outlets in the car a cigerette lighter and one middle compartment.
it seems these are only able to use when the car is turned on ...
i want to know if these could be bypassed as I want to able to use these when the car is turned off..
I know alot of cars can do this..any ideas would be appreciated.thanks
rock88 is online now Add to rock88's Reputation Report Post Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old May 20, 2009 | 06:05 PM
TunerN00b's Avatar
Default Re: Honda civic 2006 coupe..bypass lighter to stay on
So rewire the power line.
As it stands, the fuse gets power with ignition. If the fuse is only for the lighter, replace the source with a constant on source instead of the ignition active source.
If the fuse is for multiple accessories, run a fresh wire from either the battery or other source with a fuse of the correct size directly to the lighter, unless you want all accessories on the same fuse to always be active.
Outlaw-Hondaz
Oct 6, 2010 09:02 PM
Gvis420
Sep 18, 2008 06:28 AM
abusedvtec
Mar 15, 2008 07:19 AM
talkJDM
May 29, 2007 10:06 PM
