Fujitsu A6025 Lifebook laptop Almost new!!!
Old May 20, 2009 | 05:30 PM
ekx4's Avatar
Default Fujitsu A6025 Lifebook laptop Almost new!!!
I've had this laptop for about 2-3 months never really got around to using it as much as i thought i would need it.
here are the specs
The LifeBook A6025 notebook was designed to make your move from that outdated PC desktop to a sleek powerful Fujitsu LifeBook an easy decision. Its advanced Intel Core 2 Duo Processor means you can now take heavy-duty computing power anywhere. The clean design gives the A6025 style, and the crisp Crystal View LCD display makes viewing work or movies a complete pleasure. Transform that large desktop to a portable powerhouse with the Fujitsu LifeBook A6025. The Fujitsu Lifebook A6025 Notebook features Fujitsu quality you can depend on and stylishly packaged for those who want it all.
Features
* Processor: Intel Pentium Dual-Core T2130 1.86 GHz
* Screen Size: 15.4" WXGA (1280 x 800)
* Memory: 1 GB (512 MB x 2) / 4 GB (max)
* Hard Drive: 120 GB
* Optical Drive: Dual-Layer Multi-Format DVD Writer
* Networking: Gigabit Ethernet 10/100/1000, 802.11a/b/g
* Integrated Features: Speakers
* Security Features: Fingerprint Sensor
* Graphics Controller: Intel 945GM
* Operating System: Microsoft Windows Vista Home Premium
* Battery Life: 4 hours
* Weight: 6.6 lbs
Manufacturer Fujitsu
Manufacturer Part # FPCM32303
System Type Notebook
Processor Type Intel Pentium Dual-Core T2130 1.86 GHz
Multi-Core Technology Dual-Core
64-bit Computing Yes
Data Bus Speed 533 MHz
Chipset Type Intel 945GM/ ICH7-M
Cache Memory Type L2 cache
Installed Size 2 MB
RAM Installed Size
Technology DDR II SDRAM - 533 MHz
Memory Specification Compliance PC2-4200
Features Dual Channel
Storage Hard Drive 120 GB, 5400 rpm ultra-DMA 150, SATA; protected by Fujitsu Shock Sensor technology
Optical Storage Type Dual-Layer Multi-Format DVD Writer
Card Reader Type 4 in 1 card reader
Supported Flash Memory Cards SD Memory Card, Memory Stick, Memory Stick PRO, xD-Picture Card
Display Display Type
15.4" TFT active matrix
Max Resolution 1280 x 800 ( WXGA )
Widescreen Display Yes
Features
Color-Enhanced Crystal View WXGA TFT display; Brightness 450 nits; contrast ratio 600:1;
Viewing Angles:
Side to Side = 120 degrees
Up and Down = 90 degrees
Video Graphics Processor / Vendor Intel 945GM
Video Memory Dynamic Video Memory Technology 3.0
Max Allocated RAM Size 224 MB
Max Resolution (external) 1600 x 1200 / (16.7 million colors)
Audio Audio Output Sound Card
Audio Codec RealTek ALC262 with wavetable
Input Device(s) Spill resistant 87-key full-size keyboard with 19 mm key pitch and 2.7 mm key stroke
Telecom Modem Azalia MDC1.5
Max Transfer Rate 56 Kbps
Protocols & Specifications V.90
Networking Networking Network Adapter
Wireless LAN Supported Yes
Wireless NIC Integrated Atheros Super AG Wireless (802.11a/b/g)
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g
Expansion Expansion Slots Total 2 ( 0 ) x memory
1 ( 1 ) x CardBus - type I/II
1 ( 1 ) x ExpressCard/54/34
Interfaces 1 x audio - line-out/headphones - mini-phone stereo 3.5 mm
1 x microphone - input - mini-phone stereo 3.5 mm
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x modem - phone line - RJ-11
1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x display / video - S-video output - 7 pin mini-DIN
5 x Hi-Speed USB - 4 pin USB Type A
1 x IEEE 1394 (FireWire) - 4 pin FireWire
Miscellaneous Features Stereo speakers, wireless LAN antenna
Embedded Security
* Security Lock Slot
* Standard biometric fingerprint sensor; also works as a scroll button
Compliant Standards
* FCC Part 15B Class B, FCC Part 15C, and FCC Part 15E; IC ICES-003 Class B and RSS-210
* UL-cUL Listed
* FCC Part 68; IC CS-03
* CE Marking ( Not supported when configured with the WLAN module)
* ExpressCard ID EC100096
Power Power Device External
Type Auto-sensing 100-240V AC; 80W, supplying 19V DC, 4.22A
Battery Technology Llithium ion, 10.8V, 4000mAh, 43Wh
Installed Qty 1
Capacity 4000 mAh
Run Time (Up To) 3 hour(s)
Operating System / Software OS Provided Microsoft Windows Vista Home Premium
Software Adobe Reader, Microsoft Internet Explorer, Norton Internet Security 20071, Fujitsu HotKey and Fujitsu Driver Update Utility, LifeBook Application Panel, CyberLink PowerDVD, PowerProducer, PowerDirector SE, Roxio Easy Media Creator, Bluetooth Utility software CD , Google Desktop, Softex OmniPass finger print authentcation and password management software, Fujitsu shock sensor utility
Environmental Parameters Min Operating Temperature 41 °F
Max Operating Temperature 95 °F
Humidity Range Operating 10 - 90%
Dimensions
(W x D x H) Unit 14.17" x 10.43" x 1.55"
Weight Unit 6.6 lbs
http://www.google.com/products/catal...m=1#ps-sellers
I paid 750 for this new, but im willing to sell the laptop and carrying case i bought for 650.
the laptop is still in very new condition i haven't used it for more than 2-3 days.
Willing to trade for Nintendo Wii plus cash on your part.
Old May 20, 2009 | 05:35 PM
killinthemwithcleanness's Avatar
Default Re: Fujitsu A6025 Lifebook laptop Almost new!!!
where you located?
Old May 20, 2009 | 05:36 PM
ekx4's Avatar
L.A. Area
Old May 20, 2009 | 10:22 PM
ekx4's Avatar
nhgdhrf
Old May 21, 2009 | 11:03 AM
ekx4's Avatar
203
Old May 22, 2009 | 11:06 AM
ekx4's Avatar
fsfdsfdsfds
systemoverload
Sep 28, 2009 11:19 PM
Victor Penner
Mar 3, 2003 07:41 AM
