lower raditor hose geting hot plz help
Old May 20, 2009 | 11:56 AM
b16racereg6's Avatar
Default lower raditor hose geting hot plz help
Ok whats up honda tech my 95 accord today while i was driveing started to smell like anitfreez it was at normal temp so i stoped and took a look no leaks or anything so i wait a few to let it cool down just in case ride home with the heat on. and then i feel then i get home and look again and the lower hose is really hot when i touch it is it suppose to be hott? im gona put a tstat in it tonite. but is it suppose to get warm anything i should check????? please help thanks ....
Old May 20, 2009 | 12:17 PM
JDM_CD7's Avatar
Default Re: lower raditor hose geting hot plz help
Thermostat may need replacing.
Make sure you have water in the radiator first.
Old May 20, 2009 | 12:55 PM
raceACCORDingly's Avatar
if one hose is considerably hotter than the other it sounds like the tstat is stuck.
Old May 21, 2009 | 10:24 AM
yeah it was stuck i threw one it was prety easy added some 5050 to it works awsome now. butt now im haveing issues with the brake master cyl i got it all all but cant get it to slide off the boster idk why maybe rust. but i wacked it with a 5lb sledge and no go.. anyideas?
91EF_Si
13
Feb 2, 2009 10:24 AM
obuhmyuh
May 27, 2007 02:09 PM
Gir
13
Oct 23, 2004 02:16 PM
APEXI Si
Apr 27, 2003 06:44 AM
