Garrett A/R .42/.48 turbo
Old May 20, 2009 | 10:04 AM
mytj2000's Avatar
Default Garrett A/R .42/.48 turbo
How much power can this turbo put out? Stock LS bottom end/head, RC 440 injectors. It's a A/R .42 , .48 . when will this turbo spool up?
Old May 20, 2009 | 10:38 AM
gsrauto98's Avatar
Default Re: Garrett A/R .42/.48 turbo
sounds like kinda a littler turbo, should spool up fast, not sure how much power it can handle though.
Old May 20, 2009 | 11:01 AM
mytj2000's Avatar
yeah, it is a smaller turbo
Old May 20, 2009 | 01:55 PM
Silva Bullit DC4's Avatar
Post pics. Sounds like its a Garrett straight t3 60 trim (aka the "Super 60"). Reaches maximum pressure REALLY fast and early. Its capable of 320 whp, but thats pushing it WAY past its efficiency range.
Your 440 cc injectors will limit you to 300 whp, but I would not advise to push that turbo that far. Others will chime in, but thats just my opinion.
Old May 20, 2009 | 02:28 PM
mytj2000's Avatar
I'm looking to make around 250-275hp , will this turbo be reliable around that power? How much boost will it take to achieve this power goal?
Old May 20, 2009 | 02:34 PM
You should be fine. And how much boost will depend on how effective your setup is. In any case, your tuner will use whatever psi your setup will give him to make that power goal.
Good luck, should make a really fun and responsive street ripper! ;-)
Old May 20, 2009 | 02:44 PM
mytj2000's Avatar
Thanks for the info, I'm trying to make a fun daily driver. Anyone know a good tuner in washington state? also needing someone to re-chip my ecu. Looking for a good reference.
Old May 20, 2009 | 04:01 PM
PhantomX's Avatar
Im ruinng the exact same turbo on my car.... you'll def. make 250hp on a good tune.....Spoolz up super quick
Old May 20, 2009 | 05:56 PM
mytj2000's Avatar
What kind of setup are you running? Hp numbers?
Old May 20, 2009 | 06:10 PM
PhantomX's Avatar
Stock LS motor....also w/ 440cc injectors tuned on crome..only thing i did to the motor was add a skunk2 intake manifold... the car was a blast to drive, only got it street tuned so i dono the exact hp, still fast though
Old May 21, 2009 | 11:41 AM
mytj2000's Avatar
will the stock map sensor work? Do i need a check valve or a up graded mapsensor?
Old May 21, 2009 | 12:00 PM
90sedan's Avatar
If you could post a picture of the turbo it would help. There are a couple different sized .42/.48's but you should be able to hit you're goal with either of them. It may just take more boost if its smaller.
SpeedFactory is the only shop that i can recommend. It's honestly one of the only true "one-stop" shops around, where they can take care of pretty much everything in house and not to mention their top notch work. I would contact James at SpeedFactory about your set-up, he will be able to help you out. Check out their website, speedfactoryracing.net.
(Btw i'm not an employee of SpeedFactory, just a satisfied customer for over 2+ years.)
Depending on how much boost you end up running will determine what is necessary. It might be a good idea to just upgrade to a 3 bar map sensor to start.
The stock map sensor can read up to ~11psi anything after that and you will need to run an upgraded map sensor. Do not run a check valve set-up.
Old Feb 19, 2017 | 12:20 PM
Harold Allen's Avatar
I have the same turbo. Would it do well on my 2013 Jetta. Found a bigger one for my prelude wanted to see if it would work on Jetta we have sitting
Old Feb 21, 2017 | 09:53 AM
Slosc2's Avatar
You could sell it to me! Been looking for a 42/48 for quite some time.
street_ride14
Jun 21, 2008 09:27 PM
b20turbovtec
Feb 3, 2004 04:07 PM
SPOON_BeIgHtEeNsEe
Jan 28, 2004 05:17 PM
jaM3s Bond
11
Aug 6, 2003 11:39 AM
