90si
Im a heavy duty mechnic havent done much on automotive yet. So basically Im a still a newbie on honda's. I bought my 90si hatch, little bit rust but I wouldnt mind. wanna start to swap B16A in just as a process of learning. And of course, some other modification, just to get familiar with these little thing.
(1) I wanna do a rear drum to disc conversion first, wondering what is a decent swap kit that is available out there, like an OEM stuff.
(2) I can order the whole thing like:
http://www.tigerjapanese.com/index.p...mart&Itemid=26
What is the engine mouts that I need for that? or any other extra stuff that I need?
I will do some more research at the same time if you guys can give me some hint here that will take me to a shortcut here. Thanks.
rear disc conversion is a simple bolt for bolt swap. just get everything off a 90-93 integra. as for mounts, you just need b series in ef mounts hasport, avid, ebay everywhere has them. you will also need b series in ef shift linkage same people that make mounts make the shift linkage. good luck
