92 accord need help asap
Old May 19, 2009 | 09:41 PM
cloudconnected85's Avatar
Default 92 accord need help asap
k this is the prob. the engine is only firing off of 2 cyl, the #3 and 4. when i pull the wires out of 1 and 2 nothing happens. it is getting spark to them and i can see and smell fuel on the plugs.
can anyone help me please
f22a i believe with external coil
Old May 19, 2009 | 10:22 PM
mayfly's Avatar
Default Re: 92 accord need help asap
ok well here are sum suggestions. maybe your dizzy is firing wrong. or bad wires. really those are the only main problems with this situation. try changeing wires, then spark plugs. and if u need to then a new distributor, and make sure you hook up the right wires to the right spot! or you will get all sorts of weird problems
Old May 21, 2009 | 01:07 PM
tried new dizzy, diff wires, swapped injectors around, nothing works
grasslegacy
Nov 23, 2009 08:11 PM
Faultless18
Dec 9, 2008 01:54 PM
utn
Jun 26, 2007 01:36 PM
EkLanta
Jan 14, 2006 12:46 PM
shivic
Jan 4, 2004 04:36 PM
