91 Civic LX B18a1 smogged?!
Old May 19, 2009 | 07:51 PM
91civiclx's Avatar
Post 91 Civic LX B18a1 smogged?!
I have a 91 civic lx and i'm getting an B18a1 tomorrow. I can do the swap not a problem, but i have never taken a car to the state reff so i have no idea how that goes. Can anyone enlighten me on what would be the simplest way to get it to pass the insection and smog thanks!
Old May 19, 2009 | 08:05 PM
SpoonEF90's Avatar
Default Re: 91 Civic LX B18a1 smogged?!
obd 0 stuff is fairly simple to reff. well B18A's in EF's i should say.....
just make sure your wiring is clean, and the motor being swapped in must be same year or newer than the car. and the ECU must be same ECU for the motor (same obd and all)
as long as u get a clean "running" motor (not jus clean) and have your wiring done right(since im guessing...91 LX so its a 4dr....duel point poo) you should have no prob with ref.
good luck
Old May 19, 2009 | 08:31 PM
91civiclx's Avatar
thanks a lot man that helps me quite a bit, what about cost? Reff Cost?
Old May 19, 2009 | 11:04 PM
EF9Si-T's Avatar
Its about $30. Unless the rates have gone up. But it should be no more than a standard Smog test. The rest would be determined on the condition of the motor you get.
xprometheusx
16
Jul 14, 2014 12:26 PM
grubber420
Jun 28, 2010 10:05 PM
d_EG COUPE
Mar 4, 2008 09:39 PM
ekslax
Sep 23, 2006 03:52 PM
Redtail
Nov 10, 2004 02:01 PM
