Help, spluttters
Old May 19, 2009 | 07:12 PM
gsr96cx's Avatar
Default Help, spluttters
I need help Honda guys. I just did a b18c jdm gsr swap into a 98 civic ex and now my car splutters at mid rpm range and my tachometer is not working. I used the ex harness and rewired it to obd1. I also used a jumper harness obd2a to obd1. What I had to do was cut and rewire plugs; injectors, distrubitor, IAT, alternator, and extend my o2 sensor.
I have a cell light and it is reading code 4 which is the ckp sensor, but I am running a chipped p28 ecu. And code 10 which is the IAT.
I checked just incase I had my TPS switched around with my MAP sensor and I actually had them in the right location.
Please help, I searched but had no luck. Another thing that I was wondering is if it is possible that an injector in the wrong firing order will cause this.
Vehicle is drivable but it will have a fuel cut off after 3000rpm if you floor it.
Please help!!!!
Old May 19, 2009 | 07:19 PM
hOnda_hiEn's Avatar
Default Re: Help, spluttters
i had the same problem.. redline at 3k rpms.. i had to rewire a new harness.. i couldnt figure it out.. sorry.. but as for the ckp sensor.. use this trick..
http://technet.ff-squad.com/ckftrick.htm
Old May 19, 2009 | 08:05 PM
gsr96cx's Avatar
Thanks for the link.
gsr96cx's Avatar
anymore ideas I really need help.
Robert Taylor
Honda Civic (2001 - 2005)
Aug 6, 2018 03:39 PM
mugenEJ1_777
22
Aug 29, 2009 07:24 AM
rafimos
Feb 8, 2006 06:39 AM
R6Elmo
Sep 10, 2003 10:58 AM
dreweg
Jul 3, 2003 01:47 PM
