can you smog a gsr swap on a 89 crx si in california?
Old May 19, 2009 | 06:06 PM
hellraiser7492's Avatar
Default can you smog a gsr swap on a 89 crx si in california?
or is it considered an illegal swap? just wondering, thanks!
Old May 19, 2009 | 06:10 PM
Default Re: can you smog a gsr swap on a 89 crx si in california?
biizzzzump:D
Old May 19, 2009 | 06:28 PM
SpoonEF90's Avatar
you mean Can you Ref a GSR in a CRX? or just smog it? cause if you pulled up to a smog shop in a gsr crx, most wont mess with it.
i have seen them ref'ed in the past, but the ref has become more strict to wut they well allow fly. such as ECU has to be same OBD as the motor, so if 96 GSR u need run 0bd2 GSR ecu...in a 89 crx with out a jumper.....yea.
ive had a couple cars refed back in the day, 90 CRXw/91 LS (Easy), 93 SI w/ 95Gsr (easy), 96 civic ex w/ LSV 98' B18 block/99' B16 head (dont ask how)
but from wut i hear, due to cali's f-ed up buget the cal ref is closed.
anyways hope this helps, and good luck!
Old May 19, 2009 | 06:39 PM
iwanttokillgod's Avatar
nothings changed its still the same the ECU has always had to be same OBD as the motor
Old May 19, 2009 | 06:40 PM
chivid's Avatar
the Cal-ref isnt closed. they reopened in november of 2008. theyre were shut down in july 31,2008 but were reopened in november. heres a link:
http://www.jdmuniverse.com/forums/ho...ar-info-3.html
Old May 19, 2009 | 06:41 PM
ty!
Old May 19, 2009 | 06:46 PM
quick question;
what if the guy whos selling me the already swapped gsr motor had it ref'd already, do i still need to? or do i just worry about smog?
Old May 19, 2009 | 06:58 PM
jo7man4's Avatar
can you bar a DOHC ZC?
Old May 19, 2009 | 07:01 PM
what exactly does that mean?
Old May 19, 2009 | 07:28 PM
chivid's Avatar
Originally Posted by hellraiser7492
quick question;
nope , no need to since the car is legal under anyones name.
Old May 19, 2009 | 07:34 PM
so
in that case does he have to have paperwork from the reg station stating that the swap is clean?
or how do i go about smogging it, if they wont even take a conversion such as this regularly?
Old May 19, 2009 | 08:12 PM
quick question;
if the car is bar'd then no but if the swap was bar'd in another car yes it will need to be re-bar'd
Old May 19, 2009 | 08:55 PM
chivid's Avatar
yup couldnt have said it better.. for the DOHC ZC smog, you cant smog those motors so forget about it... get someone to get you a hook up on smogs..
Old May 19, 2009 | 09:26 PM
mayfly's Avatar
i live in south sac and damn sac is so hard to get smogged. but ya does anyone got the hook us or know w shop in sac area? cause i need to pass smog to get my reg up to date. and it currently wont
Old May 19, 2009 | 10:08 PM
Baserloks's Avatar
can you get a zc sohc smogged with the mpfi conversion in a ef in ca without any trouble...i know smogging the zc dohc is a dead end...!!!
Old May 20, 2009 | 12:35 AM
Spoon Sports's Avatar
Suit up
It's possible to BAR a DOHC ZC but your going to have to do some adjustments
Old May 20, 2009 | 08:10 AM
hushypushy's Avatar
Not just the same OBD, but it has to be the exact ECU for that particular motor.
For example, there is only one way to BAR a ODB1 B16, and that's with the P30 ECU, because that was the only ODB1 B16 ECU we got (on the del Sol VTEC). There are plenty of other ECU's that work but you have to use that particular one in order to pass BAR.
SOHC ZC is nothing to worry about. I have said setup in my car and from what I've been told, BAR will reject you because it's like putting a D16A6 in.
The basic law is that you can't change anything related to emissions without it being CARB approved, and that includes intake manifolds. However, MPFI is already OEM so it's fine. It's possible that a complete ******** cop will give you a ref ticket for having a SOHC ZC swap, which he shouldn't, but then again California cops can pretty much do anything to pick on you so just try to stay as far away from them as possible
How? They usually want you to make it into a USDM equivalent...I'm guessing you could BAR a ODB0 DOHC ZC using first gen Integra gear?
Old May 20, 2009 | 06:27 PM
chivid's Avatar
idk about DOHC ZC being bard either. i wouldnt even try to. just get a SOHC ZC .
nipcup101
Apr 21, 2008 02:41 PM
dapump2003
Jul 23, 2006 03:18 AM
EFin' Kyle
Aug 1, 2004 10:20 AM
IgniteTeg
Jun 4, 2002 04:06 PM
